hi guys me and my coworker are building a 60s g***er and we need info on where to score a pair of stools that go under the springs for a 56 chevy 210 sedan weve been looking for a genuine suspension inch and a half peice but all we get online is a hot rod mag article by rick del gado and we keep on hearing that the company went belly up please help this is the last peice we need to finish the front suspension if you have the part is it possible for you to take pics so we can get an idea of how to make our ownif we have to..... thank you!!!
Not sure what you mean by stools but if your looking for the cups that the coils set in,try Speedway.
http://www.jalopyjournal.com/forum/showthread.php?t=353434&highlight=ball+joint+spacers http://www.jalopyjournal.com/forum/showthread.php?t=227752
I used weight jacks on mine, trimed them to fit the frame and welded them in "you can screw them up or down" then used 73 montecarlo springs. you can look at my pics and see how i did my lower control arms. ricks 55 was a big insperation and i got lucky and scored the spacers from a local old timer that had them on a 55 wagon. p.m. me if you have any questions! cya herb.
