What's this worth?
Discussion in 'The Hokey Ass Message Board' started by dagenesta, Sep 24, 2010.
  1. dagenesta
    dagenesta
    Is this engine something that would be a candidate for a jalopy engine? This flathead military surplus engine has been in use as a generator for about 50 years. It came out of a chicken house last week, where it had been in place since the 60's. It was run once a week for 20-30 minutes, and serviced twice a year. The engine is in good shape, it was only replaced because the generator needed some work, and they got a good deal on a used replacement power unit which is a little newer (slant 6 :D). Anyway, my boss was going to s**** it. Not sure how much the engine weighs, but I think it might be more valuable than s**** price. What would you give for this engine?
  2. patrick66
    patrick66
    Advertise it in the Cl***ifieds and find out.
  3. 61 chevy
    61 chevy
    it ran on propane gas, not to good for a car,
  4. BADBIRDCAGE
    BADBIRDCAGE
    from Virginia
    Continental engines are great industrial engines. Used in tons of fork lifts over the years as well as generators and irrigation pump engines. I don't know how it would work in an automotive application due to camshaft grind. Usually industrial engines are designed to be at torque peak around 2500 rpm and they can run there all day long.
    I would figure it to be worth between $250 and $450 as a running unit. If your boss was going to s**** it I would shoot for the $250.
  5. rotorwrench
    rotorwrench
    Besides aircraft engines, Continental made all sorts of engines for military equipment from little one cylinder jobs, two bangers and little opposed 4 bangers on air compressors. I don't know how easy it would be to find parts though unless you know about some big warehouse full of old surplus somewhere. Hercules also made many small engines for generators and I know those are hard to find stuff for.
  6. arkiehotrods
    arkiehotrods
  7. historynw
    historynw
    Find an old truck that needs a heartbeat. Probably have to do some work on it.
  8. Richard/SIA
    Richard/SIA
    from No. Nevada
    Having been run on propane that engine will be incredibly clean inside.
    Try the military vehicle clubs, some one wants it.
  9. Antny
    Antny
    from Noo Yawk
    If boss man is going to s**** it, then offer to take it off his hands for a 6-pack of his favorite beverage. You can always use it for a project.
  10. batt69nova
    batt69nova
    from OR
    Converting from propane to gas and vice versa is very easy. Just a bit of carb work (and a fuel pump).
    The bigger issue is that industrial engines usually only make power in a very narrow RPM band-if cams are available for it, then that's no big deal. Might make for a decent cruising motor, as it probably makes all of it's power down low-could probably idle along all day down the highway...and get decent mileage doing it.
  11. 55 dude
    55 dude
    just went through similar issue with yale forklift motor and good luck finding camshaft for higher rpm use. these engines were made for these applications: ones that required low rpm's!
  12. theHIGHLANDER
    theHIGHLANDER
    Continentals were used in wood boats. For hipo or performance stuff I'd look at some of the more established marinas and marina suppliers. There's stuff out there if someone wanted to find it. Then again, how hard or costly is a re-grind?
  13. guitar man
    guitar man
    from Tulsa OK
    I think they put those in some of the checker cabs too IIRC.
  14. Well, up here I could get $200 a ton for it... ***ume it weighs between 500-1000 lbs... so $75 or so -
  15. George G
    George G
    Exactly F all.
  16. dagenesta
    dagenesta
    Thanks for the input, everybody.
