th 400 question
Discussion in 'The Hokey Ass Message Board' started by 31 stude, Sep 25, 2010.
  1. 31 stude
    31 stude
    i just got a th400 tranny and the yoke is bolted into the tail does any one know wut it takes to change it to a slip yoke?
  2. squirrel
    Get a yoke that doesn't have a bolt hole in it.
  3. 31 stude
    31 stude
    so i can just replace the yoke?
  4. HotRod31
    HotRod31
    I have welded up the hole & used the bolt-on as a slip yoke with no problems.
    Later, Mark
  5. squirrel
    Should be able to. They made a few different styles...try not to get the one that has the long sleeve at the front, and the vent hole in the back, as it's designed to be used with an O ring on the output shaft.
  6. Deuces
    Deuces
    That's odd........ I never seen a yoke that bolt's in the tail shaft on any trans..
  7. 31 stude
    31 stude
    thanks for all the info !!! ya i had never seen a bolt on yoke i think it might be from a truck trans with a telescopic drive shaft
  8. squirrel
    The bolt on yoke was used in one ton trucks and Vettes.
  9. 31 stude
    31 stude
    just found slip yoke for 700r are they interchangable
  10. squirrel
    nope, should be too small.
  11. I got a yoke for mine from Inland Impire drive shafts, but you would have to replace the output shaft and tail housing to convert it to regualar. I found out the hard way.
  12. Crosley
    Crosley
    from Aridzona
    Dennys Drive line has sold the slip yoke for the O-ring design out put shaft for years... they are online too
  13. I'm practily in that guys backyard but bought my yoke and drive shaft from the other side of the country. That's all I'm going to say about that. Here's Inland's web site http://www.iedls.com/
  14. r759ca
    r759ca
    from nor cal
    i know for a fact that a slip yoke will work did it to my sons 63 chev pu
  15. 31 stude
    31 stude
    you know wich yoke will work for sure?
  16. 31 stude
    31 stude
    to:r759ca wich slip yoke did you swap it with and did you have to change tail shaft?
  17. I tried to put a regular th400 yoke in that trans I have and it bottomed out after only going in a few inches. When I matched up the depth it went in just as long as the bolt on yoke was, which is about half as long as the regular yoke. If I remember the yoke wasn't splined all the way to the end like a regular yoke either.
    Check out my thread about this yoke http://www.jalopyjournal.com/forum/showthread.php?t=177928
