Trying to id this ******,got it in some parts traded ,it was bolted to a sb Chevy ****tershield,here are the numbers H3 c-81929 g 250939 on side shifter plate095664Z On small factory tag B-11x1 the side plate has 10 bolts holding it on.The vent is on top of tailshaft close to mounting bolts.Had a Hurst 4-speed shifter mounted to it.Any help will be appreciated, pictures wouldn"t load will keep trying.
i maybe wrong but it looks like a np435 new process look at this link http://www.drivetrain.com/parts_catalog/manual_transmission_overhaul_kits/np435_overhaul_kit.html
NO,definitly not a np435 this ****** is a side loader,.difference between it and Muncie,Saginaw and BorgWarner is it has 10 bolts holding the side shifter cover on.thanks for the try anyway.
A833 mopar trans. here's one of the pics you emailed me, you need to make them smaller (resize) to get them to load here.
It is definitely a good trans. Looks like you have the 23 spline version. There was also a heavier duty 18 spline version for the Six Pack and Hemi cars. The 23 spline will take a lot of abuse though. It also looks like yours is the B-body version from where the shifter mounting pad is, probably made between '64 and '69. If it was a B/E body version, there would also be a pad near the rear of the trans. The input bearing retainer should be either 4.35 or 4.8 inches. Keep that in mind if you look for a different bellhousing.
