Customs A Kustom Question
Discussion in 'The Hokey Ass Message Board' started by thewishartkid, Sep 27, 2010.
  1. thewishartkid
    thewishartkid
    When putting "55" Chevy headlights on a "50"Chevy, What size rod should i use to build the eyebrow? Do I want the top of the fender to slope forward or build it up to be level? Will this look good with fender chrome? I kinda like it!
  2. Kensey
    Kensey
    from Pittsburgh
    Why build the eyebrow, use the 55 metal. It's already done for you.
  3. thewishartkid
    thewishartkid
    I remember seeing a story somewhere useing basic s**** in the garage yo do this!
  4. FatDaddy53
    FatDaddy53
    the repop radius' dont work too good . its not a hard fab job... use 1/8" rod its easy to work with
  5. SlowandLow63
    SlowandLow63
    from Central NJ
    They absolutely need the slight slope. Don't make it look like the car is falling alseep though.
  6. pimpin paint
    pimpin paint
    from so cal
    Hey,
    To deside which version of the mounting of the '55 Chevy headlamp door you like try this. Go to a craft store and score some modeling clay (I've used plaster of paris for the same thing, but it's kinda messy and not as quick), now mount the door. Pick the straight top look and tape the door in a straight line with the top of the fender. With the clay, fill all the gaps between the door and the fender and smooth and blend in the clay just as if it were metal or filler. Now, stand back and study the mounting from all angles. Now try the lower position, and again ,study the shape. Ya, you can do the same thing with tape & cardboard, but the clay gives a more ''real-world'' look and feel to the study.
    Your head would look good on a pike "
  7. thewishartkid
    thewishartkid
    I went to a friends house today and 55 eyebrow is about 1/2 inch.I could use 1/2" conduit.
  8. thewishartkid
    thewishartkid
  9. Pinstriper40
    Pinstriper40
    I always use 3/8" rod when forming panels. You'll have to form the lip of the eyebrow with a thicker rod most likely, but 3/8" is a nice workable size.
  10. thesupersized
    thesupersized
    i used the whole headlight area from the 55 chevy fender on my shoebox for 2 reasons, i like the thickness on top, and i dont like when the bottom of the headlight bezel is right up against the fender, therefore, when using the chevy fender, the fender is built up underneath the headlight bezel(makes it look more like the fender was made for the headlight bezel and just pasted on with a fender cap on top) I'm not sure if im explaining this right, ill have to include pictures...
    the slope is definately neccessary, has to be natural looking....
  11. thesupersized
    thesupersized
    theres a flat teal-ish/aqua-ish, '50 or so chevy sedan i believe...it has 55 chevy headlights, shoebox taillights, buick sidetrim, scoop in the quarter panel, 53 chevy grillshell i believe with an imperial grill??(if memory serves me right) i don't have pictures of it, but maybe someone else does, the headlights look real good in that car..it was at this past years KOA show in gettysburg..
    EDIT: it's in the background of this pic of my car...anyone got good pictures of it?
  12. 40fordtudor
    40fordtudor
    Really like what you've done with the shoebox---fresh and different.
  13. thewishartkid
    thewishartkid
    Thanks thesupersized thats something to think about.
  14. thewishartkid
    thewishartkid
  15. koolkemp
    koolkemp
    It was featured in Kustoms Illustrated a couple of years or so ago....
  16. roddinron
    roddinron
    Personally, I think the stock radius of the 55 brows looks a little too "heavy" on an earlier car. I'd use rod and form it, I think that gives you more control over the final look.
  17. axle
    axle
    from Drag City
    George "The gator" Kilger 51 Chevy - built in 56.
  18. Old Gold
    Old Gold
    I used 1/4" barstock and some sheetmetal. Cut and welded headlight ring to french them.
