i'm running 42-48 spindles on my modified project, and i'm wondering if anyone knows if i can use f100 juice brake backing plates and drums on them. if so what modifications would need to be done?
It will bolt up,you have to use a pair of timken 14116 inner bearings,& a pair of CR services 15214 oil/grease seals.Your local bearing wharehouse can cross reference these part #'s with another brand if they do not have these in stock.You use the stock outter bearings.
well i'll be a son of a *****!!! here it is if anyone else missed it! in TECH: BRAKES..........F100 brakes on 37 to 48 Ford spindles..
