Torque Tube Removal?
Discussion in 'The Hokey Ass Message Board' started by choppermatt, Sep 28, 2010.
  1. choppermatt
    choppermatt
    Does anyone know how a torque tube separates from a 3 speed transmission in a 1949-54 chevy application? Does the back of the transmission have to come off?
  2. Bobert
    Bobert
    Remove the bolts at the end of the trans tailshaft. Slip that housing back. Slide the "ball" back and dis***emble the u joint. Warning, this is as remembered from 1959.
  3. choppermatt
    choppermatt
    thanks anyone else familiar with this?
  4. themoose
    themoose
    Sounds right to me
  5. Curt B
    Curt B
    Removing the 4 bolts on the ball collar is required but if you're removing the rear end you can just disconnect the springs and slide it back and it will slip off the yoke without dis***embling the u joint.
  6. choppermatt
    choppermatt
    thats even better.
  7. jcmarz
    jcmarz
    from Chino, Ca
    Just buy a shop manual and learn. It's not that hard.
