cloth braided spark plug wire
Discussion in 'The Hokey Ass Message Board' started by ASPHALT RIPPER, Sep 28, 2010.
  1. ASPHALT RIPPER
    ASPHALT RIPPER
    im running an hei distributer and want cloth wires anyone know were to get them
  2. chaddilac
    chaddilac
  3. Road Runner
    Road Runner
    I got mine from brillman also, but they are solid copper core.
    Not supposed to run solid core wires with HEI, because of the EMI/RMF interference that screws up the electronic ignition module.
  4. delaware george
    delaware george
    from camden, de
  5. mart3406
    mart3406
    from Canada
    Some industrial supply and military surplus places
    sell cloth braided sleeves. Maybe you could find
    some in the right diameter to slide over the standard
    HEI plug wires.
    Mart3406
  6. stude_trucks
    stude_trucks
    When did they stop using cloth wires on spark plug wires in the US? I'm guessing post WW2 maybe? My '53 Stude had cloth wires for the normal wires, but I'm guessing rubber jacketed for the spark plug wires.
  7. Max Gearhead
    Max Gearhead
    from Wisconsin
  8. Skirv
    Skirv
    I recently saw an ad for cloth covered spark plug wire that was safe for use with electronic ignitions. I made a mental note but I can't find the information now although it is available somewhere.
  9. greazhonkey
    greazhonkey
    Sacramento vintage ford has insulated cloth braided wire, look in the Model A catalog under bulk wiring. They have 10-14 gauge wire
  10. langy
    langy
    I'm also looking for some.
  11. R&C did an article or two just a little while back on this- I believe the company they used was Autowire.
  12. HOTRODSWE
    HOTRODSWE
    Its the "Vintage parts" company, just order a kit!
    http://www.vintagereproductionparts.com/
  13. M.Edell
    M.Edell
    You can use The Solid Core Wires with the Pertronix Ignitor but not the Ignitor II.I always get my wires through the Hot Rod Company, he's a HAMB Vendor
  14. morepower
    morepower
    from northeast
    Question for HOTRODSWE, are you happy with the spark plug wire from Vintage Reproductions? Is it safe for EI with synthetic core and vintage cloth braid shell? Thanks.
  15. gump
    gump
    When did people stop using cloth braided spark plug wires?
  16. 30dodge
    30dodge
    from Pahrump nv
    RestorationStuff.com has it by the foot in 7mm, 9mm, 12mm in different colors and patterns
  17. DGuidotti
    DGuidotti
    Sacramento Vintage Ford does real cloth wires, with the rajah ends and everything. They also do really nice cloth wiring harnesses as well. Do not get the wires with the lacquer/plasticky finish they are junk and will burn the points in your distributor. I have heard nothing but bad things about them just so you know.
  18. Dad Was A Racer
    Dad Was A Racer
    If I'm running a Vertex Mag (real mag, not the pretend distributor thing) am I better off with the solid core cloth wires or the carbon noise-suppression style? I've been told that the mag's performance will drop off with "modern" wires, but that I cannot run an electronic tach with solid-core wires. My mag does not have a mechanical tach drive and that's something I would like to retain (use of a tach) so I'm damned if I do, and damned if I don't it seems.
