Hot Rods Halibrand V8 quick change rear cover question
Discussion in 'The Hokey Ass Message Board' started by Louie, Sep 30, 2010.
  1. Louie
    Louie
    from NJ
    my Culver City qc has a 2 ear cover, Ive seen some with 4 ears. Does anybody know if this was a change done over time or location of Halibrand?thanks,Louie
  2. Weasel
    Weasel
  3. thunderbirdesq
    thunderbirdesq
    I don't know the answer, but my Culver City has 4 ears...
  4. Louie
    Louie
    from NJ
    the cover has an ear top and bottom on opposite sides
  5. thunderbirdesq
    thunderbirdesq
    Weird... I can't recall ever seeing one like that, but that doesn't mean much. Maybe someone removed them at some point? Dang Louie, give that poor thing a bath!:D;)
  6. superchargednailhead
    They are probably just ground off.
  7. NOTCH
    NOTCH
    mine looks like Louies cover.. maybe the later ones had more ears.
  8. revkev6
    revkev6
    from ma
    john, looks like they are a totally different casting to me. look at the length of the rib that runs between the bearing housing bosses. the four ear has much larger housings resulting in a shorter rib between them.
    my only guess on this is the two ear cover is a "lightweight" cover with either a smaller bearing or less material surrounding it. probably a later refinement.
  9. BHT8BALL
    BHT8BALL
    If you were actually laying in the muddy infield or wet salt at Bonneville changing gears you would appreciate having 4 ears to tap the cover off. And Halibrand did increase the od of the bearings. Many of the earlier smaller bearings would lock up from metal in the oil and spin in the cover. I used sealed bearings in mine without a failure and also machined an o-ring groove in the cover to eliminate oil leaks. But if you want your car authentic you better have leaks.
  10. Corn Fed
    Corn Fed
    I've seen them both ways, but the 4 ears is definately more common. None of the 6 or 7 that I or my Dad have owned were the 2 ears.
  11. AJofHollywood
    AJofHollywood
    I've seen the two ear several times before. The 4 is more common (like C'Fed said above)
    By the way, there are a number of casting of the 4 ears I've seen with a "ding" in a rib closest to Culver. Thunderbird's doesn't have it, but mine does and I've seen other that are identical. Somebody must have damaged a master, part way through production.
  12. superchargednailhead
    Kevin
    The covers are the same size its the angle of the pic I believe
  13. NOTCH
    NOTCH
    Heres my back Cover
  14. DeadFast 33
    DeadFast 33
    from Santa Cruz
    The two ears are earlier if I'm not mistaken. They changed to the four for easier removal of the cover.
    That's what I was told when I bought my quickchange 12 years ago from the guy who had it. He pointed that out to me for some reason, cuz at that point it was something I was unfamiliar with I just knew I wanted the rear end.
    FLiP
  15. Sixcarb
    Sixcarb
    from North NJ
    Lou mine has just two ear I believe. I remember when putting together on I thought it was odd.
  16. revkev6
    revkev6
    from ma
    ok then, makes sense if they changed the bearing size for reliability. I always wondered about the tangs though as the newer winters rears I've used racing midgets you had to be careful that you werent sitting with the rear hanging down hill or you could end up with the cover and the gears falling off when you pulled off the last nut. believe me when you are in between warmups and heat races rushing to change gears, having a hot gear lube covered gear hit you in the chest then roll off into the pits where it collects a nice coating of mud and rocks ****S.
    way too much difference in the length of that rib to be angle only. one looks to be less than half an inch the other an inch or more.
    how's your truck coming btw?? heard through the g**** vine you sold the henry J and now steve is selling the 32?? whats this world coming to??!! :eek:
  17. chickenridgerods
    chickenridgerods
    from DSM, IA
    The bolt pattern and overall size of the two versions are the same. The length difference in the rib is due to the increased OD of the bearing boss in the 4-tab version.
  18. revkev6
    revkev6
    from ma
    that was my point ;)
  19. alchemy
    alchemy
    I have both two and four eared Culver City covers. My two eared cover has not been ground on. But I think both of mine take the same bearing OD? I'll have to check.
    The bearing in one of mine has a smaller ID because it was used on an A/B center section. (actually a different brand center that the Halibrand cover happened to fit onto)
  20. Shaggy
    Shaggy
    from Sultan, WA
    My dad has a 2 ear cover, he got it from a racer that blew it up in 62 or 63 but he didnt remember where he got it from
  21. Louie
    Louie
    from NJ
    thanks a lot guys.
