Antique Patina on Copper
Discussion in 'The Hokey Ass Message Board' started by deuceroadster2, Oct 1, 2010.
  1. deuceroadster2
    deuceroadster2
    Does anyone know how to get an antique patina on freshly polished copper?
    I'm looking for a process that will work fast, I'm hoping that something can be applied to the copper.
  2. OshkoshRob
    OshkoshRob
    from Oshkosh
    salt water, ask lady liberty....
  3. Don't laugh, but pee on it. The also make antiqueing stuff sold at craft stores
  4. henryj429
    henryj429
    Start by not polishing the copper.
  5. lol.....ya but I bet you can get a better antiqued affect starting with polished copper, over raw copper. IMO
  6. Horse piss. seriously. thats how roofing companies that put copper roof and gutter work up, get em where they won't blind you...
  7. 49ratfink
    49ratfink
    how in the heck do they get the horse on the roof?:confused:
  8. AJofHollywood
    AJofHollywood
    You need to look up 'liver of sulfur'. If it's a small job, get the liquid type.
  9. I found this via google.
    I'd get a fresh piece of copper and make up a solution to spray on and try it out first. If it works, then you could do the whole car with it.
    http://www.finishing.com/0600-0799/790.shtml
    The patina that you wish to apply to copper is a form of Copper carbonate that usually forms over a long period of time on items left outdoors. However to speed things up, the metal finisher has mixtures that can do almost the same thing. I would recommend that you seek out a lamp restoration shop that does metal finishing and plating. Any chemicals should be used carefully, and with full protective gear as is appropriate. One suggested formula is:
    Copper Nitrate 4 ozs.
    Ammonium Chloride 4 ozs.
    Calcium Chloride 4 ozs.
    Water 1 Gallon
    Parts may be immersed, and the solution allowed to dry on. Repeat. Another bath used many years ago was a solution of Copper Carbonate and ammonia. However, due to the fumes from the ammonia, I would not suggest that you try this.
  10. switchkid0
    switchkid0
  11. Horse piss doesn't work, you have to use a solution of 25% panther piss and 75% humming bird ****.
  12. hoof22
    hoof22
    If you don't want to mess with mixing all them chemicals, try Ivory Liquid dish soap...no joke...
    EW
  13. mullskull
    mullskull
    what are you applying patina on??
    and what color patina??
    heating copper gives some AMAZING colors...
    JAX chemicals make all sorts of patinas...ya can buy it by the gallon or quart..
    it works great and fast...
    http://www.jaxchemicals.com/
    your local metal supply house may also sell patinas..
    personally i swear by JAX..i just used there Steel and Iron Blackener on my wheels..came out killer-
    How ever applying patina is an art..there is a process for sure, no two pieces of metal are the same.. like everything else it'll take some trial and error before ya get it right-
    you may want to think about sealing it after.. wax or clear coat works great..but again it depends on your application-
    good luck, and post some before and after shots!
  14. That will darken it right? Piss will turn it green.
  15. pipty6
    pipty6
    from Tracy
  16. (shakes head)
    Shine = good!
  17. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    Now, this is just my high-school chemistry talking ... but what about seltzer? It's carbonic acid. Seems like that might be a good bet for forming copper carbonate.
  18. studhud
    studhud
    Thanks for that link its usefull info un like so many other posts on here:D
    Dave Hitch
  19. IMPALALARRY
    IMPALALARRY
  20. Usually the local metal yard will have patinas and finishing stains for metals.
    or
    Sno Bowl Toilet Bowl cleaner for Red Patina
    Muriatic Acid for Green Patina
    Liver of Sulpher for Black Patina
  21. D ROD
    D ROD
    from New Jersey
    Beleive it or not try beer. A lot of builders by me have used this trick on new construction, copper entry ways, porch roofs etc. Anyway goodluck!
  22. Swimming pool water....
  23. mart3406
    mart3406
    from Canada
    Before or after you run it through
    the horse??? :eek::D
    Mart3406
  24. AstroZombie
    AstroZombie
    By the time you collect all the humming bird ****, the copper would be oxidized already! :D
    Hmmmm.... There may be a hidden lesson in this method!
  25. Road Runner
    Road Runner
    Since we are at it:
    Vomit ... includes stomach's own HCL and much more acidic/corrosive than piss.
  26. 29nash
    29nash
    from colorado
    Amazing concept; 'applying patina'............. Akin to a traditional hot rod with
    base/clear paint job = phony.
    Natural patina on copper in high humidity = green
    Natural patina on copper in normal atmosphere = look at an old penny
  27. I stil like the horse piss way. I just don't want to be the guy to have to go collect it!
  28. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
    and how he got into my pajamas, i'll never know!:D
  29. Phil1934
    Phil1934
    Machinery Handbook has a section on chemicals to age different metals. My copy is at work, but I'm sure someone will check theirs.
  30. Muttley
    Muttley
    Give me a twenty, point me toward Del Taco and wait around a few hours.
