Removing powder coat finish
Discussion in 'The Hokey Ass Message Board' started by 2many projects, Oct 2, 2010.
  1. I read today that Permatex Gasket Remover makes good for removing powder coating.
    Has anyone else on the HAMB found that to be true?
    I'm trying to strip 2 powder coated wheels. What a chore!
    Tried sand blasting using 2 different medias, 1 cabinet and 2 different guns.
    Ready to throw in the towel.
    Is traditional Aircraft stripper better?
    Is Permatex Gasket Remover the answer????
  2. prewarcars4me
    prewarcars4me
    from Bhc, AZ
  3. CW's40TPU
    CW's40TPU
    I had the same problem some years ago, powder coater told he has to burn off with a torch, it's a plastic base so it should melt off?
  4. havi
    havi
    "Permatex Gasket Remover (item #80646). liberal coating, wait 15 minutes, and wipe off with your least favorite rag. maytake more than one try. Probably want to wear gloves and do it where ya get plenty of ventilation." This is what I posted on FTE 2 1/2 years ago. Hope that helps.... at least nobody came back and complained , lol.
  5. I had a bumper straightend once at a bumper shop and they had cut out the mounting brackets and then welded them back upside down. Unknown to me, I had the bumper powdercoated and then realized there was a problem. I used the giant torch at a gas tank shop to burn it off and it ****ed. I have heard that Tal Strip takes it off easily.
  6. Retro Jim
    Retro Jim
    If you do use heat just remember to watch out and don't heat the metal up too much or it will warp !
    What are you trying to take it off of ?
    Retro Jim
  7. thisbugger
    thisbugger
    Use a metal stripper like Aircraft Remover or Jasco which you can buy at Home Depot or Lowes. It'll peal off like paint.
  8. 60 Duce
    60 Duce
    yup used paint stripper on mine worked like a champ!
  9. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I used a sand blaster then 80 and then 220 .They were for sale so i just buffed them
  10. King Karl
    King Karl
    from N.C.
    I know that it's been a while, but would the aircraft stripper be too harsh for a set of carbs? (Dellorto)
  11. ROADSTER1927
    ROADSTER1927
    Zip strip in the yellow can
  12. oldolds
    oldolds
    There are 2 different types of paint stripper. One works, one dosen't touch powder coat. Read the ingredients. Unfortunatly I never remember what is the right one untill I read it.
  13. temper_mental
    temper_mental
    from Texas
    Ive been told easy oven off cleaner will work.
  14. Ebbsspeed
    Ebbsspeed
    If you use some of these recommended strippers to remove powder coat from aluminum, make sure that you neutralize any remaining stripper, because some of them will just continue eating on through the aluminum after the powder coating is gone.
  15. bustedlifter
    bustedlifter
    I've used Mar Hyde with great success. Picked it up @ Advance Auto.
  16. lowpunk
    lowpunk
    from berwyn, il
    This may work but Easy Off works great on removing anodizing. Done this too and it worked great!
    I've used the gasket remover and it worked great like previously said. 2-3 times at most and its completely stripped. I like to use a red scotch pad to help remove the coating and a clean one to clean the raw metal, along with a washing of soap and water.
  17. LANCE-SPEED
    LANCE-SPEED
    I've never had luck stripping powder coat with chemicals? I use a DA w/80 grit.
