Projects Tools
Discussion in 'The Hokey Ass Message Board' started by John "Gunner" Gunnell, Oct 7, 2010.
  1. John "Gunner" Gunnell
    from Iola, WI
    Doing an article en***led TOOLS YOU GOTTA HAVE FOR HOT RODDERS.
    Please send me lists of 10-15 tools you think are most important. And not the stuff we all have like sockets and screwdrivers. The more job specific stuff.
  2. Probesport
    Probesport
    Besides common hand tools....
    Plasma cutter (Miller)
    MIG Welder (Miller)
    Auto-Dark welding helmet
    Safety goggles
    machinst or welding apron
    Bead Roller (Beefed up HF)
    4.5" Angle grinder (Metabo)
    Hydraulic Press
    Sandblaster
    Chop saw
    Measuring - angle finders, contour gauges, calipers, mic's
    Body hammer set
    Shear
    Brake
    Vise
    Air compressor
    Impact guns
    Files
    Computer w/internet :)
    Those are the most commonly used items in my shop, save for basic hand tools
  3. Kona Cruisers
    Kona Cruisers
    i know this sounds lame... but safety gear... been to a lot of guys houses who had all kinds of tools and no safety gear.
    ear protection (have some extra ear plugs for your buddies)
    safety glases ( have some extras for you buddies)
    face sheild.
    proper gloves, Ie welding gloves or just a mechanic or light weight leather glove
    PROPER respirator for painting
    nitrile rubber gloves
    welding helmet
    and so on... again i know it is a h***el but it can save you a trip to the hospitol.
  4. BulldawgMusclecars
    BulldawgMusclecars
    A lot of mine were on the previous list, but here are a few more:
    full face shield for grinding (no fun pulling metal out of your face)
    Sawzall (corded and rechargeable type-great for cutting parts off junkyard cars)
    Oxy-Acytelene setup
    Clecos
    4" makita grinder, with both flap grinding wheels and cutoff wheels
    Air cutoff wheel, for tighter areas
    buffing/polishing wheel
    drill press
    band saw
    belt sander (bench mounted types)
    spray guns
  5. TIG welder
    Bosch 4 1/2 angle grinder with cutoff wheel (suicide wheel)
    Grinding wheel for above
    Flap wheel for above
    Wire cup brush for above
    Gauze Pads (for when the suicide wheel explodes)
    Duct tape (to hold gauze pads on)
    Sharpies
    Combination square / protractor
    Vacuum / fuel pressure gauge
    Multi-meter for electrical problems
    2lb cross-peen hammer (for non-electrical problems)
  6. nofin
    nofin
    from australia
    x2 on safety gear
    Pencils and paper, for figuring stuff out before you get to the metal. Also a comfy chair in which to do it. (Used also for relaxing with a beverage, general break taking and comtemplation, and for swearing in when stuff goes wrong)
  7. thegrappler
    thegrappler
    Shop vac after using all the above mentioned tools
  8. thegrappler
    thegrappler
    Sandblaster to clean up rusted parts
  9. HemiRambler
    HemiRambler
    Air compressor
    Torches
    TIG
    Bandsaw
    Vertical Mill
    Lathe
    Cold Saw
    ***ortment of Powered Hand Tools - grinders - drills - both air & electric
    ***ortment of Hand tool - snips - wrenches etc
    Tweezers
  10. 39cent
    39cent
    from socal
    full face shield is proper face protection, not just gl***es, should wear both at least when grinding.
  11. selohssa
    selohssa
    If it is for a hot rod, you need to have a hot rodded box. I metal flaked this one and have filled it with vintage Snap-On tools. This will not fit all of the tools needed but it does the job to store the common tools.
    The handiest tools that I find are the brake adjusting, alignment and measuring tools. You also need a very good selection of punches and chissles. A good floor jack and safety stands are a requirement too.
  12. Francisco Plumbero
    Francisco Plumbero
    from il.
    A nice multi speed drill press, nothing fancy, I use an old Delta with the belt from the 40"s
    Any kind of a brake for making metal bends, make your own to suit your fancy, every boy wants a brake for Christmas.
    A nice inexpensive band saw, can even be a mini bench type.
    A nice set of hole saws, the better the steel or nitrided the better, you just need them.
    A real good set of jack stands, these are harder and harder to find, money well spent unless you can bench press 3000 lbs.
    A shop light with a tough bulb, the kind you could use to l***o a goat and not wipe out the bulb.
    A nice thick mat or a cow pad so you don't get arthritis or lumbago from chilling your old bones on the shop floor.
    A nice big smiths anvil for beating junk into unrecognizable shapes and devaluing priceless NOS parts.
    I have a Milwaukee close quarters drill that I use the bunk out of, I have had it for twenty years and it's an old friend, it sure comes in handy for drilling holes in tight spots, I couldn't imagine doing a job without it nearby.
    A pondering stool, This handy device gives you a comfortable vantage point from which to view your ride. Not comfortable enough to doze in, this stool lets you imagine or say oh shoot that looks ****py or serves as a nice shelf for low projects. Preferably a wooden one.
  13. Mr48chev
    I've got a lot of the items on the above lists but one the things I find I use all the time and almost every time I work on something is one or more of my Black & Decker Workmates or one of the knockoffs of the same I have ac***ulated.
    One is holding the front axle for my roadster at the moment and two more are holding up my bicycle that I am putting a gas engine on. They get used to hold stuff I am cutting, grinding or welding, hold up a couple of planks or partial sheet of plywood to make a portable work table plus being drug around to hold what ever needs holding at a comfortable work level.
    I agree that a full face shield is a must have if you are going to be doing any cutting or grinding. Good ones cost a few bucks and may be a tad heavy to some guys but your eyes and face will appreciate it to no end.
    I prefer to have bench mounted style equipment mounted on stands as I don't like what work bench I have cluttered up nor do I like the residue off a bench grinder all over my work bench. Plus you can move them around or shove them out of the way when the case needs be.
    And buy tools and equipment as you see the need
  14. BISHOP
    BISHOP
    shotgun.
  15. john61543
    john61543
    Zip-lock bags and a sharpie.
  16. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I know a few "Tools" But not the kind you want around your car or shop:D
    Cut off saw
    ginders
    welder
    torches, or plasma or both
    engine hoist
    comealong
    florecent trouble lights
  17. thegrappler
    thegrappler
    IF your in the market for a Drill press, don't buy a cheap Harbor Freight ,tool-shop or cal-hawk, I have one and the arbor is not straight, you dont notice it on small stuff like up to 3/8 but when you get up 5/8 and bigger the bit is much longer and you can se the dang thing wobble, may be the chuck itself, But Id Buy amercan
  18. guitar man
    guitar man
    from Tulsa OK
    I like my Dremel tool a lot, it comes in handy for a lot of little jobs from cutting off screw heads to sanding, grinding in tight places, small detail work of all kinds
  19. junk yard kid
    junk yard kid
    10 to 15? comeon, thats just to small of a list. It really never ends, it should be the 10 to 15 to start.
  20. angle finder
    plumb bob
    caliper
    tape measure
    large, medium and small steel ruler
    soap stone
    welding blaket
    every shape and size C and furniture clamps
    large and small hydraulic jack
    large and small jack stands
    engine hoist (a frame chain hoist if possible)/gentry crane
    large pegboard
    rolling tool cart
    coil spring compressor
    ball joint separator
    hydraulic press
    valve spring compressor
    compression tester
    transmission tail shaft plug
    drip pans and trays
    slide hammer with all the goodies
    multi purpose puller
    seal installer kit
    5lb dead blow hammer
    GIBBS BRAND!!!!!
  21. hoof22
    hoof22
    Add to that safety gear:
    Particle Masks-multi-layer kind, not the home store ****.
    A good quality hydraulic floor jack & REAL JACK-STANDS! The 2 ton cast kind, not the split thin walled tube kind with the little pin, they tend to fall over...
    Air sanders, long board, 6" DA, 8" Killer DA, Jitterbug
    Sanding blocks, lots of them, 5" and 9" hard blocks, Soft blocks and hand sanding boards.
    That and a good first aid kit with BANDAIDS...Lots and Lots of Bandaids...
  22. PBR1844
    PBR1844
    BEER
    WHISKEY
    Ice (for the whiskey)
    Hammer
    Duct Tape
    Can fix or fabricate anything with the above items
  23. KrisKustomPaint
    KrisKustomPaint
    With a cutting torch and a sledge hammer everything fits.
    here's my list of stuff i like to use it might seem like an odd ball conglomeration.
    Oxy Acetylene torch set
    sledge hammer
    string (yup regular old string)
    micrometer
    square of some sort
    chalk
    scribe
    level
    plumb bob
    giant pile of ***orted steel (plate, box and round tube)
    flat slab of concrete at least 9' x 18'
    4 1/2" electric grinder
    welder (either ***orted welding heads for the torch, or mig, or tig)
    Lots of clamps - all kinds
    sawz-all
    That should be enough to chop a top, build a frame from scratch, make motor mounts, recess a firewall, fabricate suspension parts.
    Sounds like a good hot rod tool kit to me.
  24. A bouquet of flowers to calm the wife
    A broom to sweep up the mess
    A towel to soak up the blood
    Band-aids to seal up the gashes
    Lidocaine to soothe the burns
    A phone to call your friends to beg for help
    A trash can to kick when they don't want to show
    Earplugs for your neighbors so they can't hear you scream and curse
    Extra wrenches to replace the wrenches you threw in frustration
    A chair to sit and sulk while staring at your rusted mess
    A computer to check how much a project like yours is selling for
  25. Just Gary
    Just Gary
    Two fire extinguishers;
    ...One in the car, easily accessable.
    ...One in the garage, mounted on the wall next to the door where you usually enter.
  26. oldgoaly
    oldgoaly
    Damn you mean I don't need a pullmax, power hammer, 6 planishing hammers, shrinkers, stretchers, brakes, bead rollers, sm rollers, english wheels, bridgeport, lathes, welders of all types, a couple a hundred hammers,*******s and dollies........
  27. 619SquareBird
    619SquareBird
    lol... awesome!
  28. 51V8
    51V8
    Jigsaw for when your compressor breaks on you or if you dont have a good enough compressor to use a cut off tool.
    safety equipment for sure. I have taken a dremel grinding disk in the eye that shattered. not fun.
    canned air or a blow gun on the compressor.
    DROP LIGHTS- more light is always useful. I use the fluorescent bulbs, they dont break nearly as easy.
    ***orted hammers/prybars
    screwdrivers to sub as prybars
    fridge of beer.
    dual bench grinder (wire wheel and grinding wheel)
    Welder.
    full set of metal shears.
  29. Mig welder
    Tig welder
    Plasma cutter
    Good set of sheetmetal shears(KETT)
    Bead roller(mittler bros)
    finger break
    slip roller
    Good work bench(sturdy)
    Tube Bender (jd2)
    4 1/2" grinder
    Cold saw (Dorringer) Must for doing ch***is
    safty items......Gloves,ear and eye protection
    Jacks/jack stands
    2 post lift
    Lots of superglue (to close up your cuts)
  30. racer756
    racer756
    Beautiful:D
