Eddie Meyer Intakes
Discussion in 'The Hokey Ass Message Board' started by j32, Oct 8, 2010.
  1. j32
    j32
    Hi, didn't know if anyone had any experiance with the Eddie Meyer
    high rise heated intake.This would be used on an 8ba. Thanks-Joe
  2. AJofHollywood
    AJofHollywood
    So long that it isn't meant for a V8-60 (I doubt it is) it would be fine for a 8BA. But you'll have to use an earlier fuel pump stand ('48 or before) with breather so you can get oil in there.
  3. j32
    j32
    Thanks for the info. I guess my question is are they a good intake for the
    street,or would a super dual or three two's be better? Thanks
  4. designs that work
    designs that work
    I have been helping a friend with his Eddie Meyer hi rise. Car has a 1953 Merc, aluminum heads, block relieved, ports matched and a c4 trans. Pretty radical cam and two holley carbs. As your signature says its all in the details. Do not try to plug both power valves. Yes it will run on the street and looks real nice. Jets and timing are real critical. We over heated it in the garage in less then five minutes. Have a real reputable carb man do a rebuild and start with 52 jets. You will have to do multiple plug checks and vary the jetting from side to side. Go for it.
