1950 chevy cant keep it running
Discussion in 'The Hokey Ass Message Board' started by JasonSeaver, Oct 10, 2010.
  1. JasonSeaver
    JasonSeaver
    from detroit
    I changed the oil, put a new battery in and she started up after a few cranks. Drove to the end of the drive way sat for a minute and it stalled out. Since then it only turns over when the choke is all the way out and then only for a few seconds. Help would be much appreciated.It has a newer fuel pump and a gas jugg in the trunk. thanks
  2. chevyshack
    chevyshack
    Has it sat for a long time? Could be bad gas or a timing issue.
  3. JasonSeaver
    JasonSeaver
    from detroit
    not long at all, new gas in it before i started it. the timing may be the issue. do i check it with the timing light?
  4. big creep
    big creep
    check the fuel filter too, if it has one?
  5. JasonSeaver
    JasonSeaver
    from detroit
    byp***ed it still had the problem
  6. chevyshack
    chevyshack
    Maybe its your carb. Could be gunked up and due for a cleaning. Maybe some **** in a jet.
  7. 52HardTop
    52HardTop
    It's starving for fuel. Might be something in the carb that's blocking fuel delivery? Dirt is always the culprit.
  8. Rickybop
    Rickybop
  9. hotrodlolita
    hotrodlolita
    i feel your pain !!
  10. bandit1950
    bandit1950
    from Santa rosa
    Need more info. 6v or 12v. 216/235 or small block. Single carb, pionts, what do you have. Is there a balast conected to the coil or no. Could be a bad coil. You got a trouble light and multi meter? Fill in the blanks and an answer will be easier.
  11. SLAMIT
    SLAMIT
    I say Clean the Carb!!!!!! and put on a good fuel filter or two!!!
  12. SLAMIT
    SLAMIT
    Oh and get a real gas tank. I am sure it is on your priority list though. I have "Gotten cars running" that way before to and it usually causes issues.
  13. JasonSeaver
    JasonSeaver
    from detroit
    I took the carb off and cleaned it, it started up and i adjusted the throttle and choke so it idoled nice. I had it running for 5 min turned it off and when i tryed to turn it over again the starter just clicked. I enjoyed a very brief moment before the car took it away. Any tips on getting a starter working let me know Thanks
