235 Down Draft Tube MOD...
Discussion in 'The Hokey Ass Message Board' started by Chico's Chop Shop, Oct 10, 2010.
  1. Chico's Chop Shop
    Chico's Chop Shop
    I understand the purpose of this device and was curious if there is any way of modifying it so it doesn't piss all over my freshly sealed driveway?
    Any ideas / suggestions truly appreciated...
    Thanks...
  2. gimpyshotrods
    gimpyshotrods
    That's the one. You'll get less oil blow-by past the rings too.
  3. squirrel
    make sure the deflector plate is in the block. It's a sheet metal plate held in with two screws, covers up the hole inside the block, so oil won't get out so easily.
    It should not leak oil out the tube. Something's wrong.
  4. Chico's Chop Shop
    Chico's Chop Shop
    It doesn't really leak... It's just the occasional drip... Annoying. Thanks for the info!
  5. 50's dreams
    50's dreams
    from colo spgs
    Another trick that I learned from on old circle track guy, is to work the down draft tube into the exhaust. It will held build a little bit of power as well
