Anyone ever put 1952 f2 body on a later (89) chevy frame?
Discussion in 'The Hokey Ass Message Board' started by 19f1, Oct 10, 2010.
  1. 19f1
    19f1
    from Norcal
    I have a 1952 f2 and I also have a 1989 1 ton chevy ch***is that I was thinking of mating anyone ever done this?
    Would it be easier to use the 52 frame and upgrade gear?
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    Forget that idea! Chevy ch***is is much to wide track for starters.
  3. Shaggy
    Shaggy
    from Sultan, WA
    If you want to update it a newer ford 3/4 ton axle like dana 60 will bolt in and there are people that can drop the axle. Other than rear ratio, there is very little reason to "upgrade" the suspention.
  4. FrozenMerc
    FrozenMerc
    Use the original ch***is and save your self a ton of headache. Rear end swaps are a breeze, and there are a hundred different options for the front. Everything from using the original I-Beam to Mustang II to Dakota and Aerostar IFS swaps. I have seen way to many ch***is swaps with these trucks that are just plain wrong.
  5. 19f1
    19f1
    from Norcal
    Is there a heavy duty Ifs not a fan of the rack and pinion
  6. bobj49f2
    bobj49f2
    Any pre-'73 Ford rear end will bolt in. After '72 they are wider. No one makes a IFS for these Fords as far as I know.
  7. FrozenMerc
    FrozenMerc
    Other than the looks, what's wrong with rack and pinion???
  8. 19f1
    19f1
    from Norcal
    Not thrilled but I want to upgrade the stock suspension so I will have to see I checked on the Dakota kit to no avail is there a decent kit that's pretty easy or is mustang the best?
  9. Shaggy
    Shaggy
    from Sultan, WA
    It's not like a straight axle is a bad set up on a truck, they are still used on a lot of rigs, probably a dropped axle and sway bar will improve handeling considerably, mabey some screwing with spring rates too
  10. FrozenMerc
    FrozenMerc
    The only kit I know of is those based off a Mustang II. Using a Dakota IFS would require stubbing the frame. I run an original (not a kit) Mustang II under my '51 F-1. It works fine, but my trucks hauling days are over. If you were going to be using your F2 for hauling, towing, etc I would look for something more robust.
    But like ****gy said, nothing wrong with a dropped straight axle either. I have ridden in a couple of straight axle cl***ic trucks that ride as good if not better than my '51 with the Mustang II, after the owner rebuilt and upgraded the bushings, shocks, springs, etc.
  11. bobj49f2
    bobj49f2
  12. 19f1
    19f1
    from Norcal
    Thanks guys I'm a general contractor so I wanted the flatbed to show up to jobs and maybe deliver supplies but not more than a half ton could handle but I still want it to look like a 3/4 ton.
    I may leave it the way it is and upgrade the brakes and rear end.
