52 Buick turn signal/brake light question
Discussion in 'The Hokey Ass Message Board' started by youngster_'52, Oct 13, 2010.
  1. Hey Guys,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:" /><o:p></o:p>
    <o:p> </o:p>
    i have 52&#8217; Buick and am putting in a Ron Francis wiring harness. <o:p></o:p>
    The kit is set up to use a newer style GM steering column. <o:p></o:p>
    I am using the original Buick column though. The turn signal switch has 6 wires coming of (diagram).<o:p></o:p>
    The Buick used to have 2 light bulbs each side. I am now using a single unit with a 2 filament bulb.<o:p></o:p>
    I got the old turn signal switch working but can&#8217;t figure out how to hook up the brake lights. When the turn signal is activated and I hit the brakes, the light just stays on and doesn&#8217;t flash like it should.<o:p></o:p>
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    From the looks of that wiring diagram you will have to use a seperate bulb for the TS in the rear.
  3. is there no way to make it work with the stuff i have?
  4. squirrel
  5. thanks alot Jim,
    just ordered it, if that's going to work, it will make my day!!
