I got a chance to wire brush all the loose paint rust etc.. on a car trailer.. Went to Ace wanted Rustoleumn ... They only had ACE brand paint Salesman says its the same.. Put the first coat on and it seems transparent . Anyone use this stuff with good results and how "many " coats are needed ... ACE sales man did not help with a call I made after the sell..Txs using the Allis Chambers Orange
Is the marble rattling like it should? Shake,shake,shake. Then take it back and ***** slap him for selling you ****. Bail out, rinse,repeat.
Sorry I got a Gallon of paint for the trailor.. So far one good coat on can see through it tommorrow secound coat..? hopefully big improvement..
hey guys i know i am new here but i am also the manager of an ace hardware in northern cal. he may have sold you the wroung base what is the 6 numbers on the botom of the can? did he have to mix the color? i have used ace paint on many of my project including a tear drop trailer, frame on my rock crawler, and stands for tools i have built and have never had problems with it. the only thing i can say is bad about the ace rust stop is that it takes time to dry.
With apologies to roversam, I have used that paint and it is like water compared to Rustoleum. Let's be honest here, Rustoleum is the standard and anything else is a compromise. I say sand it off and start over.
I just found this thread and I just finished painting my frame with this ace rust stop. Covers well and was not like water,it was kind of thick. I hope this stuff is durable.I got the same spiel from the ace guy when they did not have the semi gloss in Rustoleum. Three coats will take a while to dry. Do you think I can put some Rustoleum over this stuff it`s an alkyd enamel.Pete
