What rear do i have....year
Discussion in 'The Hokey Ass Message Board' started by Leadsled612, Oct 16, 2010.
  1. Leadsled612
    Leadsled612
    Bought a 50 Merc......GM drivetrain....350 sbc, 700c4 trans, 8.5 10 bolt rear. However I need parts for the brakes. Not sure what year the rear is??? And what vehicle it's from???
    Numbers are: Axle= 2FB 0 286
    Lower housing No.= 555771
    Top housing No.= 276
    Misc marking= CFD
    Wheel cylinder= 15/16 2940
    Brake drum= 3853714
    DRUM size DIAMETER= 9 1/2 inches
    Please if anyone has any info I would appreciate it
    thanks, Wes
  2. squirrel
    what size are the brakes? diameter of the inside of the drum, and width of the shoes. Most are 11 x 2 or 9.5 x 2
    What is the wheel bolt pattern?
    Also if you take a picture or two, we like that.
  3. Leadsled612
    Leadsled612
    see additional pictures
  4. squirrel
    It sure looks like a 7.5"?
    no FB code in my book that covers up to 1975
  5. koolit
    koolit
    from cen cal
    Looks like the rear in my S-10
  6. squirrel
    That sounds likely
    still uses the 9.5 x 2" brakes though....right?
  7. koolit
    koolit
    from cen cal
    Never put brakes on it...
  8. swade41
    swade41
    from Buffalo,NY
    Looks like the rear in that henry j I just bought, I don't know what it is either but measuring in at 48 inches backing plate to backing plate I'd say mine is an S-10.
  9. koolit
    koolit
    from cen cal
    Looked up the brakes up says 9 1/2 X 2 1/16
    Hope it helps 2000 gmc sonoma 2.2L 5spd
  10. Mr48chev
  11. Thirdyfivepickup
    Thirdyfivepickup
    that's a 7.5 or 7.65 rear no question. Definitely not an 8.5
    here is a pic of an 8.5
  12. Leadsled612
    Leadsled612
    so its a 7.5 gm 10 bolt rear with 2.56:1 gears......do you know what year it is? I need shoes, brake cylinder, springs, etc.
  13. squirrel
    2.56 gears were common in the late 70s-early 80s before overdrive came along. But not in pickups, just in cars. Interesting. And you have 15/16" wheel cylinders that bolt in.
    I dont know, best bet is to head to the parts store with your parts, and look up various cars/trucks that it might be, and see if they match.
  14. enjenjo
    enjenjo
    from swanton oh
    Tell the parts store 73 Chevelle, the parts will fit.
