HELP!! I need to identify this front end.
Discussion in 'The Hokey Ass Message Board' started by flight75, Oct 16, 2010.
  1. I have soem concept drawings in a 72ish Hot Rod or Motor Trend and the original actually pretty sleek looking. When it got to production is where it got fat and ugly!
  2. flight75
    flight75
    I will post some more photos in a couple hours. I think you guru's will be able to positively identify this front end with the new photos, this thing has a goofy spindle setup. Thanks for all of the help so far guys. I found a parts pic of the pacer r&p and it is a good representation of what I have.
    Steve
  3. Blades
    Blades
    from Chicago
    yuck!
  4. Why, spindles bolt to uprights? If so, AMC.
  5. mart3406
    mart3406
    from Canada
    Yeah, all AMC's (not counting the Jeeps and the
    FWD Eagle and Alliance, etc.) from the last ones
    produced and going back at least to sometime
    the 1950's had bolt on spindles. A**** other
    things, the 'bolt-on' feature makes them popular
    for building trailer axles, because if you ever
    bend or otherwise damage one, you can replace
    the spindle rather than re-doing the whole axle.
    Mart3406
  6. 31Apickup
    31Apickup
    I have an older Chiltons Manual and it has an exploded view of a Pacer front end, looks just like the one in the picture. AMC's also have a 4.5" bolt circle and GM style calipers.
  7. flight75
    flight75
    So here is a more detailed photo of the spindle... Does this help anyone make a positive ID on my front end??
    Steve
  8. pugs
    pugs
    from Hamburg Pa
    its a pacer for sure, i have a set of upper and lower A arms and some other stuff if you need spares
  9. flight75
    flight75
    Cool I will keep that in mind. No that we have a conclusive idenity to this front end is the a way to tell what year the front end is. I know they were only produced from '75 to '80??? but did they have any changes in those years, or can I go to the auto parts store and order a ______ for an AMC Pacer.
    Thanks for all the help guys.
    Steve
  10. mart3406
    mart3406
    from Canada
    No changes in the front end parts for the
    5-year production run of the Pacer. I haven't
    cross-referenced anything, but I'll bet that
    most stuff, like calipers, pads, rotors, wheel
    bearings, ball joints, spindles etc are the same
    as other AMC cars going back a bunch of years,
    so finding parts should be no problem. The
    steering rack and *probably* the A arms are
    unique to the Pacer though.
    Mart3406
  11. flight75
    flight75
    Thanks,
    Steve
