Projects 1958 MG Magnette build
Discussion in 'The Hokey Ass Message Board' started by 251 Garage, Oct 14, 2010.
  1. pimpin paint
    pimpin paint
    from so cal
    Hey,
    HUMMMMMMMMMM! Needs the A Posts cut down, a re work of the Header Bow & to loose the two back doors! I'm jus glad there arn't many of these about in California!
    " Humpty Dumpty was pushed "
  2. I took the sun visors apart, trying to come up with something different. They were just fiberboard panels covered in cloth. I cut some green plexigl*** to the shape of the originals and sandwiched them in the brackets.
  3. I don't have a photo of the shift lever, but here are the dimensions. We turned down a section of 300 series stainless to emulate the original Magnette lever, but much beefier to fit an appropriate knob :)
  4. And here is the interior fully ***embled. Forgive the photo quality - I've been too busy driving the car I never took some of my own, so these are from a show I went to.The original front seats were trashed, so for now I'm running the front seats from an MG1100. The pattern matches the rear (which is completely original) but they are vinyl.
  5. jakespeed63
    jakespeed63
    Holy talent search Batman! ..rust repair, engine rebuild, trans fabrication and now wood veneer??? Nicley done! Subscribed
    Thanks to this thread and two cups of coffee, it's now way past my bedtime. :p
    JT
    p.s. funny how all THIS fine craftsmanship, coinsides with a custom built Rolls Royce speedster, that Nads and I saw today. :cool:
  6. spiderdeville
    spiderdeville
    from BOGOTA,NJ
    looks good , my old college instructor raced MGs and wrenched on them up in Oneonta, NY
  7. mrspeedyt
    mrspeedyt
    with all you've done so far probably would cost some bloke about $40,000 to have done. i'm really impresed!!
  8. oil'n'rust
    oil'n'rust
    from NewZealand
    Oh I say that's absolutely lovely old bean. Still needs a v8, MG did have at least one, Rover/Buick.
  9. mart3406
    mart3406
    from Canada
    Yeah...usually nothing....not even carrying
    current....but not always. And when that
    euphemistic 'brown' , 'blue', 'white', ''purple
    or whatever colour wire in a Lucas system
    does do something, it will usually get hot,
    smoke and burn up! But not to worry though!
    It's all part of a brilliant design! Lucas
    engineers were smart enough to foresee any
    and all potential problems and thus, most
    Lucas-made electrical components are very
    cleverly designed to protect any fuses and
    circuit breakers in the system by burning up
    or out, first!! :eek::eek::D
    Mart3406
  10. Richard/SIA
    Richard/SIA
    from No. Nevada
    Lucas has NOTHING on Delco-Remy!
    The Delco starters and alternators are disposable units, the m***ive sales volume is what keeps them cheap.
    Stores do not even ask for an exchange unit anymore.
    I have probably owned at least four times as many Lucas parts as Delco, and still had to replace far more Delco parts.
    How many Delco parts that have sat around as long as the maligned Lucas parts are still working?
  11. lostforawhile
    lostforawhile
    Have you considered more detailed photos on how you did the carpets? i'm very interested, on my project i would have to cut the daylights out of a factory carpet. also have you seen a supplier for the short velocity stacks? I have a set of 38 MM Hitachi su type just like what would come on an early Z, I would like to find some shortie stacks to fit in my air cleaners
  12. mart3406
    mart3406
    from Canada
    I agree....it's absolutely crying out for a SBF
    or even a little 215 Buick/Rover! If ya' just
    have to keep it a 4-banger, how about at least
    going to a 2.3 Pinto 4 from the T-Bird Turbo
    coupe that you snagged the ****** from?? A few
    years ago I helped a buddy in Texas engineer
    and build a 2.3 Ford turbo motor with a
    homebrew mega-squirt EFI injection for
    his OT, mid-'70's Ford sub-compact car
    that I know better than to mention by
    name here.:D He ended up with some bucks
    in the engine for good parts (Esslinger head,
    Crower rods, JE pistons, hybrid T3/T4 turbo,
    60 lb/hr injectors etc., but it wasn't that
    radical and was still very street drivable.
    With only a mild tune and the wastegate
    set at a relatively low (for what the internals
    were actually built to handle) 20 lbs. boost,
    it dyno'd at a bit over 420 hp at 5000 rpm.
    How cool would that be in an otherwise
    'stock, sedate and elegant looking' - and
    also, still banger-powered MG??!:D
    Mart3406
  13. lostforawhile
    lostforawhile
    I think he's planning a period supercharger setup, I have a feeling there will be more vintage performance parts to come, this will more like a four banger with early speed stuff
  14. 29bowtie
    29bowtie
    :eek:Thanks 251 Garage, your restoration skills are inspiring, but your detailed photography and ability to communicate the tech, is also outstanding. Maybe for a future build, get out the big shoe horn and build something like this one.;) It's a 478 cubic inch HEMI, with stage-V heads.
    Thanks Metalshapes, for letting it roll.
  15. Try working on Citroen electrics - ALL the wires are pale green and the colour coding is a small plastic collar at each termination. Of course, with older cars all of these coloured collars have faded to an even shade of hearing aid beige.
    Brilliant work on the MG btw - looking forward to seeing it with a supercharger.
  16. klazurfer
    klazurfer
    EXCELLENT THREAD !! Thank you 251 Garage !.. ****load o nice work we all can learn from, .. Most excellent :):):)
    Klaz
  17. S1B
    S1B
    I agree, what agreat build!
    JT are you talking about the yellow Rolls?
  18. Regarding the carpet, I had the original ratty originals to use for patterns. I just allowed extra material to account for the slightly higher modded tunnel. I don't have any other detail shots but I can take some if you're interested!
  19. Nads
    Nads
    from Hypocrisy
    I got pics but I can't transfer 'em, I'll figure it out.
    This is a sweet build, but I prefer 'em a bit more hacked up and transformed.
  20. James D
    James D
    There´s "two doored" one going together in the UK. A bit pro street for this site, but it goes to show what can be done.
  21. lostforawhile
    lostforawhile
    did you glue it down, sew it together? etc. maby you could start a thread in technical on this subject, not everyone likes bare floor pans, The job you did has a nice finished look. I'm sure a lot of people would be interested in a tech thread, it pretty much applies to any car.
  22. lostforawhile
    lostforawhile
    there's your horsepower in one!! 50's car, tons of horsepower, I say it fits in pretty good. There are a lot of early pro street cars on here. I don't think anyone would complain if it showed up at the HAMB drags, it certainly meets the year cutoff. not something you see every day, that's for sure.
  23. koolkemp
    koolkemp
    Great thread ! Glad you upgraded your photobucket so I could check it out...that car is craving some subtle custom bodywork:D, awesome job!
  24. Ed Zackley
    Ed Zackley
    from Hokeyhomey
    Oh, that woodwork is beautiful. And those Brits are crazy. No way you could make money selling a car that labor intensive. It'd be like driving around in BuckingHAMB Palace!
  25. tubman
    tubman
    Boy, when I saw your pictures of the rebuilt dash, it took me right back to 1966!:D Hadn't thought about that car for years! Thanks, and great work!
  26. S1B
    S1B
    Anything new on this one?
  27. rustyhood
    rustyhood
    Quality work, Nice job!
  28. F&J
    F&J
    x2... I'd like to know how to do around the raised tunnel, etc.
  29. spiderdeville
    spiderdeville
    from BOGOTA,NJ
    Did the mg ever get done ? :)
