What is the strangest piece of metal you used?
Discussion in 'The Hokey Ass Message Board' started by VectorGES, Oct 18, 2010.
  1. mrhrspwr
    mrhrspwr
    from Durham,CT
    Aluminum telephone signs to make a center console, and once used the grille off an old fifties era chest freezer, it just looked to good not to use it!
  2. hrm2k
    hrm2k
    Polaris gas tank
    with an additional piece of metal, became the firewall insert in our 51 Fleetline
  3. Kona Cruisers
    Kona Cruisers
    aquamet 22 boat prop shaft for a steering shat..... That stuff is $$$$$$$$$$ boat guy ordered the wrong stuff I think it was in the $130/foot range.
  4. rustyford40
    rustyford40
    from Mass Bay
    I used industrial stainless doors for my floor
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Blk Pipe to make a spreader bar.
  6. Thumper
    Thumper
    I used baby bed rails for fuel tank mounts in one of my old race cars...:D
  7. carcrazyjohn
    carcrazyjohn
    from trevose pa
    It might not be metal but its strange I have a shifter boot .It is rouund and a plate holds it down But to keep the boot in place I bent a peice of welding rod and epoxied to the trans tunnel .
  8. LM14
    LM14
    from Iowa
    The hardest one for me to see anyone top is this. We held a Ford Powered show every year and an old man came each year with his stock Model A. We jokingly asked if it was modified or stock (knowing full well it was totally stock) and he remarked he had an aftermarket shifter in it. When we looked inside, there was a metal knee joint he had gotten replaced the year before. He talked the Doc out of it and machined it to use as a shift handle. Called it his millon dollar shifter.
    He also had a small paper sack zip tied to the steering column near the dash. That was his air bag.
    Cool old guy,
    SPark
  9. Squablow
    Squablow
    Those political signs everyone sticks in their yard have nice uncoated steel rod in them, I used some when i was rebuilding the quarters on my Edsel. I'm sure there will be a bunch of them around over the next month, I've got to go grab a whole ****load so I'm stocked up.
    A guy at the junkyard came up to me and asked me how he could cut a panel out of a refrigerator door without chewing up the edges. Apparently he could tell I'm the kind of guy who'd done that before.
  10. Von Rigg Fink
    Von Rigg Fink
    from Garage
    some one in my area got in big trouble for " borrowing" those signs..be careful;)
    I think the key is to wait until its over
  11. Francisco Plumbero
    Francisco Plumbero
    from il.
    My neighbor gave me 4, 1/2 monel bolts. He said they were for a fighter jet and cost a couple thousand dollars, they don't rust, they won't TIG, you can not cut them, you can not grind them, they are cool, so I put the 500 dollar apiece monel bolts on my exhaust, whoopty doo.
  12. gtkane
    gtkane
    I used S-10 fenders for part of my roof.
  13. Drewski
    Drewski
    I built roll pans for my F100 out of the modesty panel in a Mayline drafting table.
    Drewski
  14. Sir Woosh
    Sir Woosh
    When people ask where I got the fender skirts, I tell them they came from a 55 Olds. They really did as I fabbed them from a 55 Olds hood that was rusted too bad to save..........
    The frenched lakes dump out in the forward part of the skirts. The trim at the connection of the pipes to the skirts are 55 Olds 98 tail light trim. The small highlight trim back from that is interior door kick panels from a 63 Rambler.
    Click on the pic to enlarge...............
  15. Machined Inconel exhaust manifolds, for SRT-10 Development.
  16. RMR&C
    RMR&C
    from NW Montana
    The steering arm on my coupe is made from an old chimney flue (1/2" thick)....the grille is made from a station wagon roof rack.
  17. I used mirror arms from a wrecked semi for the fender braces on my '47.
    I ditched the stock splash pans,cut and bent the stainless arms to the right length and angle,squished the ends in a vise drilled 'em and bolted them in.
    Worked good front and back
  18. 23crate
    23crate
    from nz
    the outer skin of a washing machine.. and i heard of a guy that used some galvanised steel guttering let over from his house,, matched early model falcon sill shape
  19. 1971BB427
    1971BB427
    from Oregon
    Transmission pan used for the distributor recess on the firewall. A cake pan used to mount a set of fake Hilborn stacks under the hood of a g***er. Neither one my ideas, but they worked great!
  20. deuceman32
    deuceman32
    Took a roadside break in New Mexico. Pulled a clean piece of tin out of the dirt. Can't make a damn thing out of it. No matter what shape I beat it into, it just straightens itself out......
  21. 2manytoys
    2manytoys
    from Fresno
    Made repair panels for the back on the Divco out of parts from a Varian spectrometer. Made the gas pedal from an old aluminum ice cream scoop. Found out later it was my wifes grandmas anitque and collectable scoop.... Sure looks cool in my truck.
  22. metalman
    metalman
    I'm always on the lookout for interesting pieces of aluminum or stainless to make custom trim panels. The insert in this underdash radio box cover is scrounged trim from an old refrigerator.
    A paramedic buddy of mine gave me an aluminum baby strecher (backboard), had a nice patterned panel, built a custom battery box and some other pieces out of it.
    Was kinda creepy having it around.
  23. RobsHemiA
    RobsHemiA
    Wasnt near Roswell was it ? :D
  24. 31Hudson
    31Hudson
    Late 60's truck door panels for floor board repairs, road sign for floor boards. Made a sandblasting cabinet out of an old washing machine. Still have it, still use it...
  25. nmpontiac
    nmpontiac
    from Taos, NM
    After I cut the front clip off the 81 Monte Carlo for my Pontiac, I went down the street and got the cut-off tongue from one of my neighbor's modular homes, trimmed it up and welded it to the stubs of the subframe left on the Monte Carc*** and towed it over to the wrecking yard (60 miles) like a trailer.
  26. slim tempo
    slim tempo
    I've used an aluminum bread pan as the outside of a heater unit on my '68 El Camino. Friends laughed and still chide me about it. They never worked on a car in an emergency, and they consider themselves worldly.
  27. floydjer
    floydjer
    After reading these posts, I guess using a new sheet of 18 ga. steel was strange.
  28. dprodder
    dprodder
    This is not that strange for farm boys; early Ford/Ferguson tractor rad shrouds will work on a deuce/A rad with some modificaton.
  29. bluebolt
    bluebolt
    from Benton LA
    Base commander's parking sign for a built up area for shifter boot.
  30. fitzee
    fitzee
    Always on the look out for interesting shapes.keeping a eye to this post.
