Rear end for 27 T coupe
Discussion in 'The Hokey Ass Message Board' started by pincher, Oct 22, 2010.
  1. pincher
    pincher
    from Saginaw
    Hay all you TALL T guy's, what width rear's are you guy's running on you'r HOT ROD'S. I would like to put a 9" Ford rear under it if i can find the right width. I am looking at 58 to 60 mounting surface to mounting surface.Plan on a chanel on the car, no chop.26-27 Coupe's. ,,,,,,THANK'S.........PINCHER
  2. hey ive got a 56 olds in mine. fits perfect
  3. pincher
    pincher
    from Saginaw
    Nice ride skunk victum, what width rear is that?.........PINCHER
  4. F&J
    F&J
    ^ early Olds is 60"
    also, the 57 to 59? Ford wagon rears were 9" and the width should be in your spec range. Hard to find though.
  5. pincher
    pincher
    from Saginaw
    I have a 71 BRONCO in the 30 found the rear end in a junk yard in Indana. they are getting hard to find. going to check a couple of yard's Monday,.......PINCHER
  6. rodrobb
    rodrobb
    from Sweden
    I have a strange 9" and 57" wide.
    3.5" backspace on the rims, it`s thight
      66 KB
  7. width is as stated. i have stock 16x4.5 wheels on the rear end with firestone 700s and it fits with about 1.5 inches per side
