how do you take this apart?
Discussion in 'The Hokey Ass Message Board' started by brady1929, Oct 22, 2010.
  1. brady1929
    brady1929
    last stupid question for tonight. i would rather ask then screw something up. i have never taken one of these apart. do i remove the clip and press it out? it came from a chevy and i need the yoke for my t5 trans. thanks in advance.
  2. Shawn M
    Shawn M
    Yes, right on the money!
  3. 1959apache
    1959apache
    hold a socket that is almost too big to fit in the hole with a pair of channel locks and use a hammer or mallet. Works every time and makes it quick and easy.. after removing bolt clips on both sides of course
  4. First: save yourself the time, that yoke is fubar'd. The rust that is amply evident will never allow a seal, leaking all the trans fluid faster than you could replace it.
    Second: Squeeze the clips with a plier to remove. Might take a screwdriver to pry them out of the recess.
    Next, secure two sockets, one sized just smaller then the bore, one sized to allow the cup to easily enter. Place in vise and tighten just enough to remove one cup. Then reverse to press out the remaining cup. Easier to show than explain, sorry.
    Cosmo
  5. squirrel
    Sand the rust off with 400 grit sandpaper and solvent or light oil, see how bad the pitting is. Might be ok, might be junk, it's hard to tell from the pic
  6. DD COOPMAN
    DD COOPMAN
    Not tryin' to "poo poo" your yoke but THAT yoke probably isn't going to do the rear seal in your T-5 any good. IF I had a spare, I'd send it to ya. DD
  7. crotex
    crotex
    from cuero, tx
    Yeah as said above.
    Step 1. Remove both clips.
    Step two get a socket that is just big enough to fit in the hole on top of the caps, a pair of pliers, and a hammer.
    Step 3. Hammer one side all the way down until one caps comes out the bottom. Flip it over and repeat to the opposite side.
    From there I think you will see how to wiggle it on out of there.
  8. brady1929
    brady1929
    thanks and thanks for not blasting me
  9. dirt t
    dirt t
    A press also works. I am not sure I would use that yolk Its awful pitted. I think a new one at a drive shaft shop would be $17.00.Or a good used one
  10. The Hank
    The Hank
    from CO
    remove pins and put the shaft in a vice near the yoke. Smash yoke with 2 lb hammer, two joints will come out. Follow above using a socket for the remaining two.
  11. GTS225
    GTS225
    If you find, after cleaning it up, that the pitting in the yoke is rather extensive, you might be able to "repair" it with something called a "speedi-sleeve". I get them from a local bearing shop, but you might be able to get them from your local auto parts supplier.
    It's a thin steel sleeve that presses on to the seal area on a shaft, and uses the original size seal. Typically used to repair a seal-worn groove, but I see no reason you couldn't use it for this.
    Roger
  12. squirrel
    uh...how is a speedy sleeve gonna work on something that moves in and out of a bushing?
  13. 1959apache
    1959apache
    quiet you.... what do you know....
    haha
    just kidding
  14. TheWrenchbender
    TheWrenchbender
    from Belton SC
    From what I can see this one is gonna spew fluid, But cosmo has the procedure correct! I use a press myself but the vise works very well also.
  15. Andy
    Andy
    Remove the grease zerk if it was one.
  16. Flatheadguy
    Flatheadguy
    Agreed on the corroision situation. Try cleaning it up as suggested, but I doubt that it's gonna be useful. Pressing these apart I have always used either a press or a bench vise. A couple of sockets if you don't have press tools. One large on the bottom, other one one the cup (slightly smaller). Press until the cross bottoms, then flip is over and pres it out the rest of the way. Think before you go for it and you'll be fine. Never used a hammer, but I guess it'll work okay.
  17. rustyangels
    rustyangels
    Do they make a "speedi-sleeve" that long? I've only seen crank dampers and truck axle sleeves
  18. nali
    nali
    If you remove it by yourself , put a rag on it .
    You probably already know it , but a spring like this leaving is home could cost an eye to anyone .. :(
    The best scenario is earing it flying 20 feets away and loosing it in the gr*** or the mess :)
  19. fat141
    fat141
    That yoke is rat****, dont waste your time. Some one above said $17, easier to buy one.
    Save lot of headaches down the track
    Rod
  20. Von Rigg Fink
    Von Rigg Fink
    from Garage
    That Yoke is Toast:D
  21. paintcan54
    paintcan54
    I have to agree I tryed to save one once, wasted a day and more money then it was worth. Like some have said buy a new one, you'll be glad you did.
  22. ems customer service
    i agree wet sand with oil wd40 workes good, it may to pitted mybe not
  23. bonebroke
    bonebroke
    from WI.
    sand it,if its just pitted j.b. weld it,its free to try. or throw it away and, get a new one.
  24. 29nash
    29nash
    from colorado
    Yep. Rusty residue can be deceptive, especially in a picture. Polish it up and mic it. The area where the seal will be if it cleans up with less than .003 or so it'll work.............
  25. bob308
    bob308
    that yoke is junk. not only do you have a seal. but it also rides in a sleave in the trans tailhousing. tear up that sleave and you will have a vibration in the drive line that will drive you nuts.
    also i may not have the best tools mostly craftman. but a socket is used to take nuts and bolts off. it is not a hammering tool. get a pice of steel to drive out the joints.
  26. brady1929
    brady1929
    yeah guys i just bought a new one on ebay
  27. GTS225
    GTS225
    Oops!.....color me embare-***ed. :eek:
    (As dad used to say...."engage brain before putting mouth in gear.)
    Roger
  28. Mr48chev
    Take the old one off and clean it up and save it though as they make great plugs to stick in the back of a spare trans or the trans you have installed in a project to keep things clean.
    I press the Ujoints out an in with the C clamp part of my balljoint press (similar to this one bhttp://www.amazon.com/OTC-7249-Ball-Joint-Service/dp/B0002SRGXY It makes a job that was a pain in the **** pretty simple and quick.
    I've done hundreds of them with the bfh and various additional tools but can do it a hell of a lot easier and quicker the way I do it now.
    If you decide you need step by step instructions on how to put it back together with a hammer and sockets pm me and I'll walk you through it.
  29. I thought i would put a tip on how to put it all back together too, since it seems you haven't done it before, installation is about the same as putting it back together.. take the caps off and get the cross inside the yolk.. press one in, then the other.. after its all said and done take a dead blow and with medium force hit behind where the caps are pressed in. you will notice before ya smack the yolk the joint will be a bit stiff. after ya smack it it will be a smooth as ****er.
  30. 29nash
    29nash
    from colorado
    I've saved two, twice. That yoke, 50 years from now, just might be consider a "score"! It's easy to say it's junk, but we'll never know until it's actually checked. :)... of course I enjoy working on old iron, so time (used) don't necessarily mean it was wasted..................
