small block ford lakes headers , who makes good ones ?
Discussion in 'The Hokey Ass Message Board' started by dirtbag13, Oct 27, 2010.
  1. dirtbag13
    dirtbag13
    finally got the small block ford set into my roadster pickup ! looking for some advice on who makes a good set of lakes headers for the small block ford ! i was looking at speedways but am a little leary of them being cheaply made ? also looking at patriots ! any input will be greatly apreciated ! probably going to be getting them in plain steel as the p***enger side rear tube may have to be moddified slightly to clear the edge of the cowl since the firewall is recessed ? then sending them off to have them ceramic coated ! it will be close and i was thinking of ordering speedways in plain steel and if they clear then sending them back and getting the ceramics as i couldn't touch getting them coated for what their price difference is ! thanks for any help , hoping to get some input from someone who actually has these ans can comment on the quality
      10.6 KB
  2. Master of None
    Master of None
    I'm running the you weld up kit from speedway. The flanges are fairly thick and the tubes are also fairly beefy. I bought a pair of the speedway bolt on's for a sbc for a customer that had the ceramic coating. They fit well but they also tilt down, witch I didn't care for. The bolt on's seemed to be the same as the you welds as far as thicknesses.
  3. dirtbag13
    dirtbag13
    do the tubes sweep back into the cones or do they just go straight in ?
  4. Bull
    Bull
    http://www.lakeheaders.com/ - saltflatmatt here on the HAMB. I've got a set of his headers on the roadster and the Tudor that ***us is building. He will be making another set of headers for me soon too.
  5. Master of None
    Master of None
    And I forgot, the ceramic coating on the sbc set I bought, was even and looked like it was coated well from all directions. They have been con the clients car for a while and they haven't started to blue, peel or do anything else funny, that would elude to poor quality.
  6. dirtbag13
    dirtbag13
    thanks bull , i was looking at his also , do they come with dump tubes on the bottom for running full exhaust ?
  7. Master of None
    Master of None
    The tubes sweep back a little in to the larger cone but not a huge amount. That's why I built mine so they would look better.That way I could mount them level, not running down hill.
  8. Bull
    Bull
    They don't, but I'm sure Matt could add them for you.
  9. Bull
    Bull
    Personally I hate when the flange for the dump tubes is right off the bottom of the cone. I like them to be out of sight underneath the car. That's what we're doing with the headers on my Tudor. I had Matt make me a set of lake headers but ***us will be welding the dump tube right to the bottom of the cone. The flange will be at the end of the tube underneath the car for a cleaner look.
  10. dirtbag13
    dirtbag13
    i ***ume you run the baffles in yours ? i thought of going that route and not running full exhaust but am worried i'll get sick of the noise and fumes after while ! how are yours noise wise ?
  11. dirtbag13
    dirtbag13
    i agree ! if i could have a decent set of baffles and some turnouts i would rather go this route and not have full exhaust
  12. Bull
    Bull
    I ran the baffles in mine. It was still loud, the fumes were strong-ish - but I got used to that and it made black marks on the doors of the car, but I didn't have turn-outs. Worst of all though, the baffles rattled like mad. It pissed me off so I pulled them out -- and then it got crazy loud. The baffles probably could have been secured better to eliminate the rattles, but it was still loud -- even with the stock junkyard 350 that was in the car -- even louder with the stronger mill I put in the car.
    If it were my decision, I'd do a lake headers with full exhaust like on FalconMan's old RPU -- only I'd move the flange under the frame, tuck up the exhaust under the frame and add turnouts to the end of the lake header cones:
    OR
    I'd go with something like this -- which is exactly what Matt will be building for my roadster:
  13. MENACE
    MENACE
    from PHOENIX AZ
    I run a set from lakes headers .com from the alliance, 2 years on the road and holding up great, and i use the baffles from car chemistry he recomended
  14. dirtbag13
    dirtbag13
  15. hotrodnailhead
    hotrodnailhead
    from Phoenix
    Mine are from patriot and they sweep into the collector. They also came fully welded.
    Having trouble with the uplaod of the pictures though.. :confused:
  16. hotroddon
    hotroddon
    Mine are Patriot's
  17. dirtbag13
    dirtbag13
    thanks guys ! well after doing some more looking i dont have alot of room to run full exhaust under the truck and keep it hidden , so im thinking a set w built in baffles and turnouts but idk ? im gonna study it a little more and see what i can make work !
  18. Bull
    Bull
    Hard to judge from a video, but here is my roadster at full song with baffles. This is with the old low compression junkyard mill.
    <embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid85.photobucket.com%2Falbums%2Fk80%2FMNBullyBoy%2FModel%2520A%2520Roadster%2Fdrags050.mp4">
    <embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid85.photobucket.com%2Falbums%2Fk80%2FMNBullyBoy%2FModel%2520A%2520Roadster%2Fdrags034.mp4">
  19. millersgarage
    millersgarage
    I never found ones I liked, so I used the Speedway kit and made my own, then shipped them off to jet-hot to be coated.
    Even saved a few dollars over premade ones, and have the set I like. I too did not like the flange coming off the bottom, so I ran the pipes under the car and connected them with a band clamp. Almost seamless.
    Sorry no photos to post (writing this on my phone) but check my albums.
  20. Da' Bomb
    Da' Bomb
    I also used the Speedway kit, but used ****** stub flanges
    Pat
  21. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Matt is the man .....................I bought the speedway you build it headers and for the time and price Matt is cheaper and if you want swept back centers ,He can do it ,But its extra.
  22. Blue One
    Blue One
    from Alberta
    Heddman is supposed to be bringing out a set of weld it yourself lakes headers this fall. Not sure when, their ad showing them has appeared for a few months in Rod and Custom.
    Looks like they will be a nice kit.
    I like the looks of them also the Patriots are nice.
    I like the way the pipes to an under car exhaust system were run through the frame from the lakes headers of this 32 built by Hollywood hot rods.
  23. 33_chevy
    33_chevy
    from TX
  24. Master of None
    Master of None
    DRuss32 if you don't mind I'm going to steal your idea on your baffels on my next pair of lakes headers i build. Nice work! I like!
  25. sololobo
    sololobo
    The Speedway kit allows you to put them at the angle etc. you like. They are nice quality, here are Rob Lee's on his Lincoln Y-block, they were ceramic coated and after around 10k miles they look great.
  26. dirtbag13
    dirtbag13
    most of the kits i have seen don't seem to take into acount that fords heads are offset and both headers are the same length so one side ends up farther back on the p***enger side than the drivers ! anyone notice this ?
  27. hotroddon
    hotroddon
    ALL V-8 engines are offset from side to side, not just Fords. The cones in the kits come as equal length, and you just slide them onto the first tube to get the equal lengths that you are looking for.
  28. dirtbag13
    dirtbag13
    yes the do it yourself kits i realize you can do this , but all the ***embled kits seem to be equal length !
  29. Go to lakesheaders.com. They ain't cheap but have everything ya need.
  30. dirt t
    dirt t
    The only thing I would change on mine is add turn downs.
