Let's see your tunnel rams!
Discussion in 'The Hokey Ass Message Board' started by Jay.S, Sep 23, 2010.
  1. I've always run 500 Carters or Edelbrocks over the years because I found them easy to work on and to set up for the street.....mine is one of those screamers...7200 rpm. If your mainly on the track....you'll most likely be putting some gearing behind the motor ...ie 4:11 to 4:56's depending on the rearend......so you should be fine with those size holleys.....sounds like you'll have some support from your Dad.
    Look forward to seeing pictures some time of the 27.
    Best of luck with build.
  2. floydjer
    floydjer
    Not sure if this will help, But here you go.................
  3. PRO 48 fleetline
    PRO 48 fleetline
    from ohio
    282 cu.in. 15.8.1
    15% alumin heads
    2 holley 660 carbs with 850 base plates
    jesel rockers 3 step headers
    VP 120 octane
    G force 5 speed 9" rear
    6.50 gears with a 4 link
    Car is launched at 10,000 RPM's
    and then shifted at 9,600
    5th gear change is made at about 1/8 th mile mark
    and in about 6 seconds.
    0-60 1.30 / 9.35 145 MPH.
    car weights 2,965
  4. Brad54
    Brad54
    from Atl Ga
    I would LOVE to know the bore and stroke of that engine!
    -Brad
  5. buck baker
    buck baker
    ya the all look great
  6. chevy57dude
    chevy57dude
    Edelbrock Street Tunnel Ram on my BBC with a pair of Thunder Series Edelbrock carbs. And a scoop from some old Ford. Smaller plenum is supposed to be better for responsiveness. No street time on it yet but have had some fun in the driveway lightin' 'em up.
  7. fitzee
    fitzee
    Always love tunnel rams. Here is my BBC ram. it will be on a G***er projects some day.
  8. here's our tunnel ram..427 chev.
    Rick
  9. Butch M
    Butch M
    Still one of the baddest 55 chevy's on the planet........
  10. PRO 48 fleetline
    PRO 48 fleetline
    from ohio
    Brad its:
    2.750 stroke - 4.040 bore
  11. Man that sounds like one hell of a ride!
  12. usmc50lx
    usmc50lx
    from St.Louis
    Here's mine 454ci. edelbrock street ram 2 600cfm edelbrocks. Motor has slight port work on large oval ports, 9.25:1 CR, cam is .540 lift 296/306 adv. duration. Car weighs 2675 with me in it and went 11.86 at 110mph @ the hamb drags this year plus well over 1,000 street miles to shows and cruises this year.
  13. 20th Century Chevy
    20th Century Chevy
    Here's mine......350 sbc .030, flat top pistons, double hump heads, edelbrock TR1X tunnel ram, 2 600 holley carbs.
    fastcar1953 likes this.
  14. Pluck
    Pluck
    Here is the set up on my heap at back to the 50's this year. 454 big block w/ Edelbrock Street Tunnel Ram Intake, with twin 750cfm Edelbrock Carbs, all above a snotty solid lifter cam. It hauls the mail and wakes the dead. Has Salt flat matt's Lake Headers, turbo 350 trans, 10 bolt posi with 4:10 gears.
    -Pluck
  15. 296moon
    296moon
    from england
    Heres mine, I need to swap the hilborn as I dont like the bolts through the top, [​IMG]
  16. 296moon
    296moon
    from england
    And does this count?, its in a pop I`am doing for my mate, [​IMG]
  17. zrwhat
    zrwhat
    Here's mine, still working on it and waiting for the ****** Fenderwells to come back from Jet-Hot for the second time, they looked like chit the first time!
    Ain't done yet...
    Gibby
    Before:http://[​IMG]
    After
    [/IMG]http://[​IMG]
  18. Onemansjunk
    Onemansjunk
    from Modesto,CA
    This is on a 1964 T-Bird 390 Ford FE.
  19. PRO 48 fleetline
    PRO 48 fleetline
    from ohio
    This car is owned by a local engine builder here in ohio and it sounds like war leaving at 10k let me tell you amamzing lil engine.
  20. Axle34
    Axle34
    from Michigan
    usmc50lx<SCRIPT type=text/javascript> vbmenu_register("postmenu_5796993", true); </SCRIPT> - I'm interested in your setup. Your cam, is that a Comp, Crane or ?
    Flat tappet, Hydraulic, Solid or Roller?, Transmission and Rear Axle ratio? I have a similar setup on my 454, but heavier car and a 4 speed. I've been thinking about upgrading my cam to a flat tappet hydraulic with duration numbers close to your's, but wondering how much low end I would lose. How's it run around town? It sounds like it, goes like Hell at the upper end!
    Axle34
  21. Looks like a rare Hammer Port 440 :D
    Very cool, what is that Big Bad Mopar in?
  22. Another Mopar! Six Pack is not a tunnel ram, but it is right up there in the cool factor, and power production area!
    Small block mopars fit in many tight places I have found, first one I have seen in a "pop" (anglia in this side of the pond). Nice work!
  23. zrwhat
    zrwhat
    Hey moon, you gonna sell the Hilborn top with the studs coming up throught it?
    If you R, let me know,
    Gibby
  24. Jay.S
    Jay.S
    sbc edelbrock 7110 with two 500's
  25. Deuces
    Deuces
    So, who else is sportin' a tunnel ram??? :)
  26. grits
    grits
    Mine
  27. 296moon
    296moon
    from england
    Its in a Ranchero [​IMG]
  28. 1badnov
    1badnov
    from South Bay
  29. Gasser1961
    Gasser1961
    for my falcon
  30. 8FLEET9
    8FLEET9
    from MASS.
    i hate mopar and think rancheros are kinda goofy looking, but that my friend is the coolest mopar powered ranchero i've ever seen! *****in ride.
