Lets see your scratch built floor pans
Discussion in 'The Hokey Ass Message Board' started by johnboy13, Feb 3, 2010.
  1. bent metal
    bent metal
    '27 Es*** boat tail.
  2. chevyshack
    chevyshack
    Im flat broke so i started using metal from an old firebird hood i got for free. I need a bead roller though. It does the old oil can effect. I was going to buy one during black friday sales but aint happening now due to life throwing me a big *** curve ball. She's sitting idol for awhile now.
  3. dodgerodder
    dodgerodder
    Neat thread. I found a little trick when I rolled the beads in the floorpans for my rpu. I **** with a beadroller. I cannot roll a straight line for more than 2":eek:
    I set up some simple guides for the beadroller's dies to sit in. The dies I have are 1" wide. I used some 1" wide flat stock to set up a channel for the die to ride in. I set the guides 1" apart so the die would ride right down the middle. Can't go wrong, perfect straight lines every time.
    Here's some pics to show what I did, hopefully it will help the beadroller challenged like myself:
    Don't stress too much if you get a slight amount of warpage from rolling the beads. It will pull down flat when you clamp it in place to weld it down.
  4. Toner283
    Toner283
    Keep 'em coming. I have this job ahead of me yet & I am soaking up tips & ideas.
  5. Lot's of nice work here!
  6. Dodgerodder.
    Thanks for that.
    So simple..
  7. For some reason, I don't have an overall shot, but here are mine in a combination of steel, wood, and aluminum.
  8. aircoup
    aircoup
    hell ,mines the original floor just reinforced with yellow licence plates,,all over it
  9. FrozenMerc
    FrozenMerc
    Not the best shot, but the new p***enger side floor (and rockers and rear quarter) in my '62 Monterey.
    Not as pretty as some of these other floors, but then again it will be getting the full carpet treatment as well.
  10. Aviator
    Aviator
    A work-in-progress for my '34 Ford 5-W. When the transmission tunnel is complete the insulation and carpet will follow. The B&M shifter mounts on the top of the transmission tunnel.
  11. walrus
    walrus
    Damn !! most of those floors are too nice to cover with carpet or anything else, great jobs and thanks for the ideas,,,,Sam
  12. frank dog
    frank dog
    Custom Belly Roller Action on this trans tunnel.
  13. fitzee
    fitzee
    I like these kind of posts. Been building floors for years. only thing I have on my computer right now is some late model stuff.sorry.
  14. bent metal
    bent metal
    Nice work. How are you doing the intersecting beads and offsets?
  15. rob lee
    rob lee
    from omaha,ne
    Made a grid and filled in with old T running boards,fronts are removable to access the battery and clutch adj. http://[​IMG]]
  16. bent metal
    bent metal
    "FITZEE", how did you make the panel with the four pointed star design??? That is amazing.:)
  17. fitzee
    fitzee
    I overlap the beads then I work the cross sections with a hammer and dolly. On corners I end just short of each other then work with a hammer and dolly. I have only basic tools and would love to have more dies and build a press. For now I do with what I have.
  18. SinisterCustom
    SinisterCustom
  19. red baron
    red baron
    from o'side
    Thats a real good idea! I like it.
  20. tgd61
    tgd61
    Here are a few pics of my recent floor job...used 1x1 sq tube for the floor frame and 18ga sheet steel for the floor. Use propane tank, rubber hammer, my thigh, etc to get the radius's.
  21. evil1
    evil1
  22. titus
    titus
    heres a start of some floorpans going in my model A truck
  23. Da Tinman
    Da Tinman
    Can I play too?
    better pic of Jeffy's tunnel.
    Bed floors count???
    I got more but not posting pics of uninteresting off topic stuff!
  24. titus
    titus
    heres the floors all done in my truck.
    jeff
  25. BadassBadger
    BadassBadger
    from wisconsin
    not floor pan but pan never-the-less
  26. deucerails
    deucerails
    from Manitoba
    I made mine out of .080 aluminum, they will be riveted down to the stock model a cross braces. The " X " is a stamp that I made, because I wanted a radius on the inside corners and I couldn't do that with a bead roller.
  27. Bigchuck
    Bigchuck
    from Austin, TX
    My 41 chevy. A little done, a lot to go. What a pain. Why did they design this thing with so many angles to the floor? It will get there, just more later than sooner.
  28. Dirk35
    Dirk35
    Here is a quick pic of the floor I built in my 1935 PU and a couple of the floor I built for the 1949 F1 PU. I didnt put the time in the 49 ****** tunnel to make it round instead of angular like I would have liked to.
  29. bill3337
    bill3337
    Here's one of my '37 I'm building, home built cowl patches, trans tunnel, front floor sections and rockers.
  30. lawman
    lawman
    Lots of very nice work here. Tom (Tired Old Man)
