pontiac convertible top for '65 impala
Discussion in 'The Hokey Ass Message Board' started by rivera, Oct 28, 2010.
  1. rivera
    rivera
    from Ogden, UT
    quick question guys, found a deal on a '65-'68 pontiac convertible top and was wondering if it would work on my '65 impala ss convertible. the part number on the pontiac top is 4506711 if that helps. if you guys need any more clarification let me know. thanks in advance.
  2. stanlow69
    stanlow69
    65 to 68 Pontiac WHAT!
  3. rivera
    rivera
    from Ogden, UT
  4. bobj49f2
    bobj49f2
    Unless you're going after the structural parts, it looks like you'd be better off going to a top shop and having one made. By the time you get that one stretched out and having the current and future tears repaired you'll have just as much time and money into it. Just my 2¢
  5. rivera
    rivera
    from Ogden, UT
    sorry, just want to know if the convertible frames are interchangeable, thanks.
  6. stanlow69
    stanlow69
    So your frame is bad or what. DETAILS, DETAILS, DETAILS.
  7. stanlow69
    stanlow69
    Didn`t see that last post. Will call tomarrow to see if they have the same part numbers on the tops.
  8. bobj49f2
    bobj49f2
    Your best bet, other than finding a GM convertible expert, is consult a Hollander parts interchange catalog. Your local library might have a copy that covers your model years. I don't know for sure if the Hollanders would cover convertible parts or not but it's worth a try. Find a HAMBer that does, if possible.
    HAMBer Max Gearhead replied to a recent post I made and said he had them up to the '80s, send him a PM so see if he'd help.
  9. Max Gearhead
    Max Gearhead
    from Wisconsin
    I just checked my Hollander and it doesn't show any interchanges for the actual tops but does say that the lift ***embly, hydraulic cylinders & mechanical actuators, fits all full size GM convertibles from 65-68. Hope this helps.
  10. stanlow69
    stanlow69
    The 65 Impala conv top(FABRIC) has the same part number as all fullsize Pontiacs 65-70. The frames may vary in design.
  11. hustlinhillbilly
    hustlinhillbilly
    from ohio
    65 Impalas have two types of frames, the main difference being in the front bow. (Found this out the hard way.) There are some interchanges with other GM family models, but it's been too long for me to remember.
  12. rivera
    rivera
    from Ogden, UT
    thanks for the replies. max, the seller did state that in the ad, hopefully the impala falls into the 'full size gm convertible' category.
  13. rivera
    rivera
    from Ogden, UT
    trying this out one more time to see if i can get a definite answer.
  14. flynbrian48
    flynbrian48
    Since Impalas and Catalinas share the same body shell, I'd say yes. Unless you know for sure it's from a "B" body car, I'd say you'd betty buy it cheap enough to not be disspointed if it's from a Lemans or GTO!
  15. rivera
    rivera
    from Ogden, UT
    The part number has a '67' and the Impala is a '65. I believe it might be from the Catalina. Would the 67 in the part number indicate its from a '67 Catalina? If so, are they the same body shell in 65-67? Thanks.
  16. junkyardjeff
    junkyardjeff
    I think the only top frames that are different are the caddy,olds 98 and the buick electra as them might be a little longer then the rest. I think the impala,lesabre,88 and catalina are all the same and should be the same from 65 to 68.
  17. tanof
    tanof
    from New Mexico
    Bonnevilles are longer the Cats. For full size Pontiacs there were two wheelbases, three trunk lengths and a few other odd things. A Cat has is 18 feet long, a Bonneville (non station wagon) is 222 inches long. There is a difference between the trunk lengths of the two cars and can vary even more due to body style. Be careful, compare the measurements before you buy.
  18. Wicked50
    Wicked50
    You should ask this question on Layitlow.com its a lowrider forum I'm sure theres someone there that would know.
