HELP!!!! Welding issues with my MIG
Discussion in 'The Hokey Ass Message Board' started by t-town-track-t, Oct 29, 2010.
  1. t-town-track-t
    t-town-track-t
    from Tulsa
    Using my little Lincoln MIG set up on gas, and everything is wired correctly. I have checked it 3 times.
    Last time I used the welder (a month ago) everything worked perfect. It has set in the corner since. I am now using it and three times now the wire has started glowing red hot inside the welder, between the spool, and the feed mechanism. Then is smells like the coating is burning off the wire, and it stops feeding. I have pulled the wire out of it 3 times, and re-fed it, and sometimes it will let me weld for 30 secs or so, and it does it again.
    What am I doing wrong?
  2. t-town-track-t
    t-town-track-t
    from Tulsa
    while it is welding, it welds beautifully. For what its worth.
  3. 50flathead
    50flathead
    from Iowa, USA
    Is your tip clear and unobstructed? Are all the connections tight and free of corrosion?
  4. t-town-track-t
    t-town-track-t
    from Tulsa
    brand new tip, and all connections are tight.
  5. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Spool grounding inside the welder? Wierd. Do you have rodents that eat wiring?
  6. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Now that I re-read it, thinking some kind of grounding near the hose connection, after the feed.
  7. hoggyrubber
    hoggyrubber
    the olny time any of the migs i have had did that the wire was touching something inside the welder. i didn't have all the parts for tension on the spool, and it would work loose.
