Simple things we often overlook
Discussion in 'The Hokey Ass Message Board' started by Malpass, Oct 29, 2010.
  1. Malpass
    Malpass
    I posted a thread yesterday about overlooking the plug gap after switching from points to HEI and finding my lost power after regapping the plugs with a larger gap and alot of folks chimed in with their experiences and with their satisfaction of learning about the subject.
    I see we have a post today discussing the value of a properly functioning PCV system, a really good thread there with a lot of great info and tech. Its suprising how many people neglect the PCV system.
    So I beg to ask, what other simple things have you often overlooked while working on your cars that would have made your life a lot easier? and any tips to give others who might be having the same problem?
  2. Burp your cooling system after refilling it :eek::rolleyes:
  3. Malpass
    Malpass
    thats a good one, or you'll be chasing an overheating problem! Been through that plenty of times, the fill funnels that have the radiator cap attatchment are great for this.
  4. Use Blue Painters Tape over your ignition switch if you need to put oil in the engine or something else critical.
    I once drove a car that I forgot to put oil in the rear-end. Didn't remember until I heard a weird grinding sound coming from the back end. No long term damage (got lucky), but now I put tape over the ingition with a note so I don't screw up.
  5. Don't know about overlooked but I routinely cross the 5&7 wire on the SBC. I'm OK if I run thr wires over the top but under the headers is an entirely different subject.:eek:
    One thing that I have noticed that gets overlooked. There is a pole on most 12V starter solenoids that runs to the hot side of the coil on a points car. Its is 12v for start only. If it doesn't get run in most cases the car either won't start or is real hard starting.
  6. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    Bench bleading brakes works!! The push pedal method never worked as well for me.
    Also label everything when it comes off the car so you can put it back in the same place. I remeber my first 67 c10 had some left over parts(nuts,bolts) when I was done. Still runs great and never had any issues, hope they weren't important. :)
    porkn****** I seen this last night on a freinds car...funny you brought it up.
  7. Malpass
    Malpass
    I've done the same on the Chevy's ******. When I swapped dizzy's is my Fairlane, it was my first go-round with a Ford and I pulled all the wires off and starting hooking them back up like Chevy number's their cylinders, I'm thankful for that second look back to realize that Ford numbers their cylinders completely different.
  8. Francisco Plumbero
    Francisco Plumbero
    from il.
    Where was this PCV thread, I searched and am not sure which. I have to figure out this crazy howling situation.
  9. 19Fordy
    19Fordy
    When doing a clutch job on a flathead V-8 Ford put a big sign on the dash saying:
    DON'T FORGET THE THROWOUT BEARING.
  10. Malpass
    Malpass
  11. Mr48chev
    When I built my T in the early 70's it was the first Chevy V8 after driving an Olds 350 for several years and Yep, I wired it for an Olds and it took a couple of days of frustration and a middle of the night revelation before I went out at 02:30 in the am and put the wires where they belonged and fired it up. Not sure the neighbors appreciated the open headers though.
  12. Francisco Plumbero
    Francisco Plumbero
    from il.
    Thanks buddy thats an excellent thread.
  13. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    After 40+ years I still leave the rotor cap off once in a while.
  14. Malpass
    Malpass
    at the dealership i used to work at guys with even 20+ years of experience would almost weekly either a.) forget to put the drain plug back in or b.) forget to put the filter back on after an oil change and end up performing what we called a "5 quart engine flush" right onto the floor.
  15. Motion bird
    Motion bird
    MSD makes little wire tags that clip on the wires. I use them on both ends whenever the wires are going to be run into hidden spaces. They are dirt cheap and fit just about any wire exept those big cheesy dayglow type wires.
  16. Motion bird
    Motion bird
    Take the distributor cap off an engine with a rear mounted distributor when yanking the trans out.
  17. 40FORDPU
    40FORDPU
    Grounds, particularly engine block.
  18. bobs66440
    bobs66440
    from New York
    Make sure you pull the screwdriver out of your back pocket before you sit back in the car!!! :(
  19. I did an SBF back in the '80s and not only did I put the wires on in the wrong place but I ran them backwards besides.
    I can laugh about it now but at the time I was feeling pretty damned dumb.
  20. bobs66440
    bobs66440
    from New York
    Oh, and make sure all the brake lines are actually attached before bleeding or all your good brake fluid will end up on the floor and become bad brake fluid.
  21. AstroZombie
    AstroZombie
    from Marina, CA
    During my first engine swap, forgot to put the fork on the throwout bearing.... Only to find out when we tried to drive the car out of the garage and it wasn't moving! It was an idiot moment, but fun to look back on.
  22. TagMan
    TagMan
    Don't put the oil fill cap on top of the air filter housing when adding oil. If you forget to put it back on and close the hood, it'll pop a nice dent in the middle of your hood.............
  23. partsdawg
    partsdawg
    from Minnesota
    If doing brake work do not put the tire on,lower the vehicle off the jackstands and walk away before installing 2 if not all the lug nuts.It doesnt matter if it's just for dinner or a buddy called.Install the lug nuts.
  24. 61 chevy
    61 chevy
    put oil in your filter before you screw it on at next oil change
  25. Not only will it become bad brake fluid, brake fluid on the garage floor is one of the slickest substances known to man. Ask me how I know this.
  26. RodStRace
    RodStRace
    Roll down the window when the car is in the shop.
    This especially applies to later model caddys with auto locks!
    Always do a preimeter check before closing the hood. You loose the tool (best case) or have to fix the dent.
    Pump the brakes before putting car in gear!
    A bad and/or battery will cause all sorts of strange electrical issues. Always start with a good, fully charged battery. Do not p*** go, do not collect $200.
  27. bobs66440
    bobs66440
    from New York
    Yeah, ouch... and it doesn't do much for the floor paint either :rolleyes:
  28. fredb
    fredb
    How about when installing mechanical oil pressure gauge while doing several other upgrades firing up the car with the oil line unconnected to the gauge under the dash...carpet doesn't need THAT much lubrication.
  29. billsill45
    billsill45
    from SoCal
    When reinstalling the distributor cap, make sure that it's properly seated and both clips are secure. The rotor does really bad things to the cap if it's loose when the engine cranks over. I learned this the hard way.....
  30. Sir Woosh
    Sir Woosh
    Simply put, always look anything over one more time even when you think you are done. My brother dropped a tight fitting rebuilt engine in his car. Job was totally finished and was filling the cooling system for a test drive when he heard gushing and a big puddle was forming under the car. Forgot to install 2 freeze plugs and couldn't get to them without pulling the engine again.............
