Model A Overdrive
Discussion in 'The Hokey Ass Message Board' started by 4-banger, Mar 1, 2008.
  1. 4-banger
    4-banger
    from Tucson
    What are some good reasonably priced overdrives that will work on a model A? I know of the mitchell overdrive kit and the Columbia 2 speed rear end, but what are some others?
  2. Dale Fairfax
    Dale Fairfax
    Go over to "The Ford Barn" site and either search for Model A O.D.s or post an inquiry on the Model A page. There's a guy in Ohio who adapts B-W R-10s to a Model A driveshaft and eliminates the electrics. Since it goes right in the middle of the driveshaft/torque tube, it's not obvious.
  3. madmax
    madmax
    from Calif.
    Jim Norman at Old Ford Garage 1-760-749-6317 He does the Volvo units that are a bolt in for the Model A's
  4. Darwin
    Darwin
    Check out this guy:
    http://www.modelaonly.com/services
    Really good solution--really not cheap--2900bucks.
    It's a Ford T-170 trans--3speed with overdrive--converted to a bolt-in for stock A drivetrains. It may be a more complex install than a Mitchell Overdrive but it's full syncro and is also available for V8 cars.
  5. Bruce Lancaster
    Bruce Lancaster
    '40-48 Lincoln OD trans...normal V8 engine/torque tube flanges. Stock, it will have one of the close ratio ge****ts, 25 or 26 tooth, and about .7 OD, meant to be used with 4.44 gears for best results. Requires substantial driveshaft shortening.
    Lots of people have been looking at T5's with four-wheel-drive tail, which offers a nice flat place that might just accept a Ford TT U-Joint housing casting...
    That might well prove a good way.
  6. 4-banger
    4-banger
    from Tucson
  7. willowbilly3
    willowbilly3
    from Sturgis
    I have a friend in Texas that builds a kit with the topshifted toploader aluminum 4 speed as the heart. They do a lot of machine work so you don't have to hack the cross member. He gets around 2700 and that includes the shortened driveshafr/tube and everything else you need.
    His A coupe with a/c on will cruise 60-65 no problem
  8. ALindustrial
    ALindustrial
    look at nosurf's tech on his lincoln OD install... it was in techweek
  9. FORDY 6
    FORDY 6
    Dwight Bond...the guy that had Gibbon Fibergl***...makes an adaptor kit for mounting a T-5 trans. 308-468-5885 or 308-468-6237
  10. JP
    JP
    from BayArea
    I had a chance to visit Dave at his house this past weekend and picked up one of his Weber Kits. One of the nicest people I have meet and i could have spent the whole afternoon talking with him (never felt like he was rushing me out). The quality of his work is some of the best I have seen, and he has a wealth of knowledge. I look forward to getting some more of his products.
  11. pcmenten
    pcmenten
    My wife bought a 29 Model A with a dual stick transmission. I drove it and the second stick is an overdrive. I can't find any information about this. I'll have to crawl underneath it to get a better look but it is attached to the original transmission and the torque tube is attached to the other side.
    Does anybody have any idea what kind of overdrive that is? AA?
  12. fulltimeforester
    fulltimeforester
    from california
    I have a Borg Warner in my two door that works well, from a '50's stude I think. But the
    T5 from an S10 is what I'm going to put in my '31. A kit is available for 895.00, includes
    everything except the trans. Auto Restorations
    215 W. Gilbert St.
    Muncie, Indiana 47305 1-800-955-3139
    He does have rebuilt transmissions available
  13. Tedders
    Tedders
    Do you have contact info?
