My 15 minutes of fame: Got my car in R&C
Discussion in 'The Hokey Ass Message Board' started by Rex Schimmer, Oct 27, 2010.
  1. I wouldn't call it luck. I just read it myself. It sounds like you worked to get your recognition, ...... and someone felt you DESERVED it. I happen to agree with them.
    Congratulations Sir.
  2. Rusty Junk Ranch
    Rusty Junk Ranch
    Nice Rex, I guess your too famous to come to my BBQ now ???:D
  3. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    Rockey,
    Really planned to be at the BBQ but looked at the weather and just couldn't get my *** in gear. Steve said it was great so I screwed up again!
    Still want to do the cage in your Nash B'ville car
    Rex
  4. sololobo
    sololobo
    Atta boy Rex, very nice pix of the modified in the mag. Keep on keepin on man, they are never done. ~Sololobo~
  5. Jax2A
    Jax2A
    Congrats on the feature, it definitely caught my eye because I'm planning on running a Zetec/T5 combo as well. (But I've got dual sidedrafts for mine) Did you use the Quad4Rods bell housing or come up with something on your own to mate them together?
  6. Silhouettes 57
    Silhouettes 57
    NICE!!! Real Nice! Good for you.
  7. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    Jax2A,
    I think that I may have gotten the very first bellhousing that John made, it needed to have a couple of holes redone to fit my application but it has been perfect since then. Quad4Rods suggests that you use an internal hydraulic cylinder for the throwout bearing but I used the pivot bolt and the arm from a 2.3 engine and cut a hole in the side of the bellhousing and used an external cylinder for the clutch actuation, never have had a problem with it. My engine was a standard shift so it had a flywheel so I use the stock Ford pressure plate and a Centerforce disc that has the spline for the T5. Because my car is so light I am planning to try a 8.5 lb flywheel which is a lot less than the 24 pounder that is on it now. Quad4Rods has a conversion for the ignition that eliminates the need for the Ford electronics. Since my car has electronic fuel injection the ECU I am using does the ignition also.
    Rex
  8. Jigger
    Jigger
    Congrats! That's a cool little ride.
    You ever check to see what kind of milage that bangers giving you?
  9. Gigantor
    Gigantor
    Congratulations! Even though it was on the last page, I kept skipping ahead to look at all the pics all over again. That's one of those cars I want to get in and see how fast it will go - it looks like it's a LOT of fun! Nice job.
  10. HotRodMetal
    HotRodMetal
    from USA
    Cool ride. I thought that when I saw it at Bonneville a couple of years ago.
