Mystery! - Weird '6bbl' 409 Chevy F.I intake - Can anybody I.D???
Discussion in 'The Hokey Ass Message Board' started by mart3406, Sep 3, 2010.
  1. mart3406
    mart3406
    from Canada
    Mystery! - Weird 6bbl. 409 Chevy F.I. intake
    I saw this 409 Chevy '6bbl' fuel injection
    intake over on the 348-409.com list
    (www.348-409.com/forum/showthread.php?t=18908#post136936)
    but nobody there can I.D it either. It
    appears to be from a 409 marine engine
    of some sort, but that's all that anybody
    can figure out. Does anybody know for sure
    what it is, who made it, when and what the
    original application for it was? I know I've
    never seen anything like it!
    Mart3406
  2. pdq67
    pdq67
    Boy, DON'T KNOW???
    Never seen such an intake??
    What the hell is is??
    Way cool tho.
    pdq67
  3. plymouth1952
    plymouth1952
    wow Thats a wild one the ****erflys cast in the intake ?
  4. wrench409
    wrench409
    from Here
    I've seen that thread also. Seems Chevy had some stuff up their sleeves we didn't know about.
    The following pictures were captured from Ebay many years ago. The story is there were six test truck engines built for fuel injection. And they weren't sold, but in a development contract of some sort. GM collected them at the end of development phase and one survived the s****per because the truck was down for some other maintenance problem.
    Now that story being told....I have NO way of knowing the veracity of it. From memory, the Ebay seller told much of it that way. I don't know who bought it, nor do I remember the price. I simply collect digital photos from all sources for my personal collection.
    So, here we go:
  5. Max Gearhead
    Max Gearhead
    from Wisconsin
  6. wrench409
    wrench409
    from Here
    Actually no. Check closer, it's a throttle body bolted to the intake.
    And the angle on the throttle body doesn't appear to be marine. Marine engines had a much sharper angle.
    My guess since there is an absence of numbers on it, it was experimental truck development setup.
  7. RAY With
    RAY With
    No clue here but is it ever one cool SOB!Make a hell of a wall hanger in the shop.
  8. TERPU
    TERPU
    Don't know what it is! But it looks like a really great place for a 6-71 to me.
    Tim
  9. Squablow
    Squablow
    That is supremely kick ***. Would there be any way to actually run it on an engine? I'd put that ***** on my W if there was any way to make it work.
  10. mart3406
    mart3406
    from Canada
    There probably is a way.....*if* you could
    ever find one of these intakes. It looks like
    it'd be a natural to convert to EFI - fabricate
    a couple fuel rails and some throttle linkage,
    plug some electronic injectors into the
    existing mechanical injector holes in the
    ports and use a micro-squirt or other
    controller!
    Mart3406
  11. F&J
    F&J
    any chance that is diesel prototype?
    Just wondering...like the big iron V6 GMC was supposed to be a diesel, but ended up as gas.
  12. gas pumper
    gas pumper
    no throttle blades on a diesel.
  13. mart3406
    mart3406
    from Canada
    Nope. Not possible. Diesels have to have
    their fuel injected directly into the
    cylinder and always at or very near the
    point of peak compression. The manifold
    in question is set up for port injectors, so
    it's definitely from a gas burner. Also, it's
    got throttle plates to control and 'throttle'
    the amount of air flowing into the intake,
    something a diesel has no need of.
    Mart3406
  14. pcterm2
    pcterm2
    sorry dude GMC made several v6 diesels mainly 478 ci v6 toraflow,a 351{rare}and if i remember right a v12 702 diesel not gasoline engs
  15. squirrel
    Look close at the throttle body, it looks like three 2G bases hacked up and bolted together.
    I'd guess home brew.....
  16. mart3406
    mart3406
    from Canada
    The 478 V6 was made in both gasoline
    and "Toro-Flow" diesel versions, but the
    others you mentioned - the 351 V6 and
    the 702 V12 were all gas burners *only*.
    Mart3406
  17. str8axle55
    str8axle55
    from MA
    Yes, but GM may have done it that way for development/testing. It doesn`t explain the injector holes. Looks like the truck prototype, but that appears to have 4 ****erflies.
  18. mart3406
    mart3406
    from Canada
    <table id="post5610640" cl***="tborder" width="100%" align="center" border="0" cellpadding="6" cellspacing="0"><tbody><tr valign="top"><td cl***="alt1" id="td_post_5610640" style="border-right: 1px solid rgb(229, 229, 229);">Re: Mystery! - Weird '6bbl' 409 Chevy F.I intake - Can anybody I.D???
    <hr style="color: rgb(229, 229, 229); background-color: rgb(229, 229, 229);" size="1"> <!-- / icon and ***le --> <!-- message --> Quote:
    <table width="100%" border="0" cellpadding="6" cellspacing="0"> <tbody><tr> <td cl***="alt2" style="border: 1px inset;"> Originally Posted by squirrel [​IMG]
    </td> </tr> </tbody></table>
    ------------------------</td></tr><tr><td cl***="alt2" style="border-width: 0px 1px 1px; border-style: none solid solid; border-color: -moz-use-text-color rgb(229, 229, 229) rgb(229, 229, 229);">
    </td> <td cl***="alt1" style="border-width: 0px 1px 1px 0px; border-style: none solid solid none; border-color: -moz-use-text-color rgb(229, 229, 229) rgb(229, 229, 229) -moz-use-text-color;" align="right"> <!-- controls --> </td></tr></tbody></table>
    Around that time - early & mid 1960's - Rochester
    was working on a 'unitized' 6bbl carb that was loosely based on three 2GC 2bbls in a common body, as possible replacement for 3-2bbl setup used by Pontiac, but it never reached production. My first thought when I saw the pics of this intake with the 6 throttle plates was that maybe that's what it was, but that wouldn't explain the injector holes in the ports.
    Mart3406
  19. Brad54
    Brad54
    from Atl Ga
    GM was also developing a Rochester fuel injection intake for the 348... it was just like the SBC version, only for the W engine.
    Lamar Walden has it now.
    Lamar's also got two factory turbo-charged off-shore 409 boat engines. I've seen a write-up on the boat from long ago. Someone called him a couple decades ago and asked if he wanted the engines before the sunk the wooden boat in Lake Lanier.
    The turbo's, intakes, etc. are all GM part numbers.
    I've never looked past the turbos to study what they actually feed into. I don't know if there's carbs there or not. Lamar THINKS the heads are Z-11, but has never checked.
    -Bra
  20. chickenridgerods
    chickenridgerods
    from DSM, IA
    The throttle body angle wouldn't matter on a fuel injected engine since there aren't any floats to deal with like on a carbureted manifold.
    I'd expect an automotive intake for a street car to have a water crossover and a breather tube, as was used during the era.
  21. TomWar
    TomWar
    In 1964 I aquired a Corvair Engine that had come from Chevron Research
    in Richmond Calif. It had holes all over it for sensors that I had to plug up.
    That could explain what you are calling "Injector holes". When they are testing,
    they measure all kinds of things.
  22. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    I agree that it looks like three hacked up 2 bbl bases welded together. Got to be some kind of FI prototype. Manifold has no provision for thermostat or PCV fitting and a wierd *** distributor base. I'm subscribing just to find out more. Didn't the true Z11 motors have a separate t-stat housing?
  23. rusty stuff
    rusty stuff
    In early 80s saw a unit for sale in Cars and Parts ,was aftermarket for 348 trucks because of bad fuel mileage,not many were sold, dont know the brand name , this is a quite rare unit, although not a performace FI , and not GM to my knowledge Rusty
  24. chickenridgerods
    chickenridgerods
    from DSM, IA
    The Z11 intake has the runners and plenum in one part, with a separate valley cover that has the water crossover and distributor mount. AFAIK, all intakes for the Z11 heads, both original and modern aftermarket use this 2-piece type of setup.
  25. DenverDave
    DenverDave
    from Denver, CO
    Z-11 intake/ The best picture I have
  26. wrench409
    wrench409
    from Here
    Z-11 Intake Pictures
  27. Deuces
    Deuces
    Pictures saved!... Thanks Wrench! :)
  28. wrench409
    wrench409
    from Here
    I recollect a single 4 bbl intake upper for the Z-11. I had a photo somewhere of it, but cannot find it. It was on my old website hard drive that got hacked.
    If anyone needs photos of 348-409 parts, engines, cars, etc. I have thousands of pictures I never even added to the old site. Just ask....I'll likely have a shot of the part on some form.
    I even have a pictorial tear down of the Mystery Engine.
    Here's another of the Z-11.
  29. Deuces
    Deuces
    Hell Yes!! Please post those pics!!! Thanks again Wrench! :)
  30. wrench409
    wrench409
    from Here
