polishing aluminum valve covers
Discussion in 'The Hokey Ass Message Board' started by vintagetinman, Nov 4, 2010.
  1. vintagetinman
    vintagetinman
    i have recently picked up an old set of cal custom valve covers for the FE in my 57 wagon . unfortunatly they have been sitting for quite a while and have dulled and oxidized .
    i am looking for advice on bringing the shine back .
  2. Buick59
    Buick59
    from in a house
    a few cans of elbow grease usually work for me.
  3. vintagetinman
    vintagetinman
    elbow grease i have . any particular product that i should combine with it ?
  4. indyjps
    indyjps
    can you post a pic, need to know if they are pitted, general condition
  5. BOWTIE BROWN
    BOWTIE BROWN
    i media blast . Its all about prep .
  6. inlinr6
    inlinr6
    have them polished at a good chrome shop
  7. Captain Chaos
    Captain Chaos
    from Missery
    Polishing aluminum can be a pain if you dont have right tools.
    There is a guy here that does a nice job inspite of being an ***shole.
    I think he goes by aqtw31 , his name is Andy
  8. vintagetinman
    vintagetinman
    here are a few pics
  9. rockfish
    rockfish
    Depending on how bad the finish is I like to wet sand them before polishing. 600, 1200 and then 2000 grit paper. You can vary or skip grits depending on the condition of the covers. After this I buff on a wheel with 3 different compounds, but Mothers, Flitz or Semi-Chrome polish and an old towel with elbow grease will work well too, just takes a few beers longer:)
    No need to send them out for polishing. You can get great results at home. Save the money for more parts.
    Good luck.
  10. rockfish
    rockfish
    Just saw your pics. I wouldn't media blast. You'll just have a co****r finish to smooth out to get a high polish. I'd stick with the wet sanding. Just my opinion. Others may have good results with blasting.
  11. HOTRODPRIMER
    HOTRODPRIMER
    I don't know why people don't check the archives,,maybe it's because they don't know it exist, check this out. HRP
    http://www.jalopyjournal.com/forum/showthread.php?t=97179&highlight=polishing+aluminum
  12. duecesteve
    duecesteve
    I wetsanded my lt1 valve covers with 2000 grit and used mothers aluminum polish!
  13. F&J
    F&J
    On the media, if you had a blasting cabinet with worn out sand, then it might clean up those fin recesses easier than sanding. If you don't have blasting, then do it like rockfish said. You could even try different grades of steel wool before buffing if you don't have a bunch of sand paper grit numbers.
    A little bit of dull looks good between the fins, if you shine the tops of the fins real good.
    One tedious spot will be those recesses where the bolts go. Might need a mini buffing ball on a drill.
  14. HomemadeHardtop57
    HomemadeHardtop57
    Get a buffing wheel and some compound and have at it
  15. rogmoseley
    rogmoseley
    I use heavy grade liquid polishing compound and a wool pad on a body grinder. It worked good on my big truck shiny wheels and here's a b4 and after pic of mine that i did,,, still could use a little more work.
    You can also use a cotton polishig wheel and hard stick compunds if you have an arbor to put it on. They make about 4 grades from jewelers rouge to black emory. Be ready to get dirty!!
  16. F&J
    F&J
    ^ that's a good idea ^ to put the cover stuck on a piece of wood, so it stays put.
  17. I haven't tried this product, but it got rave reviews on another car forum I frequent.
    http://www.californiacustom.com/purple_metal_polish.html
    I think they used the deoxidizer and the polish from that site. I believe you can call and get a sample too.
    These pics are from a guy on the other forum...not the seller.
    Old aluminum tube
    After a 1 min spot treatment with deoxidizer shows a clean oxide free area
    After 30 sec application and buff off the residual polish
  18. 5SPOKE
    5SPOKE
    Hi, well I am a veteran polisher with 25+ years experience and I am not an "***-hole" as someone else is described as :).........All the hints and tips here thus far are good, you can do this yourself without specialized equipment it just takes time, when you do it for a living time is $$. I use a higher speed polisher and larger diameter buffing/polishing wheels than most would at home and a 10hp lrg scale polisher. Media blasting is OK, I would say gl*** so as not to make to co**** of marks in the finish, just like you wouldn't want to start with too co**** of sanding grit 'cause you have to work those scratches out and aluminum is soft. Just my thoughts, I could polish 'em for ya, for $ or I trade as well, here a picture of my Buick covers and my beast of a machine.......
  19. 5SPOKE
    5SPOKE
    Only problem here is the comparison of a aluminum extrusion (a very high grade and purer aluminum quality) than any cast valve cover is. extrusion polishing is like polishing billet aluminum 6061 or 5052, very easy to polish compared to an inferior aluminum quality thats in most cast items, along with better results as well....
  20. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I've got a buffing wheel mounted on an old washing machine motor that I buff valve covers with, along with a couple different types of buffing rouge. I've found that die cast covers (like Cal Customs) don't tend to polish up as nicely as sand cast covers (like Edmunds, Offenhauser, and the original Edelbrocks).
  21. RetroSpeed
    RetroSpeed
    I used three grades of WENOL products (Red, Blue and Pink Tubes) to polish the aluminum, chrome and stainless parts pictured:
  22. swade41
    swade41
    from Buffalo,NY
    I did 400,600,800,1500 then hit it with Wenol all by hand, took a couple hours each cover.
  23. Jeff J
    Jeff J
    Like the guys at the shows showing polishing the bottoms of soda cans !!
