Technical Cadillac flathead horsepower tricks
Discussion in 'Traditional Hot Rods' started by 38FLATTIE, Feb 7, 2009.
  1. keeper
    keeper
    from So Cal
    Wow that is a sweet proposition, I will have to think about that. May have to give me a purchase price just in case I fall in love with them.
  2. RichFox
    RichFox
    One thing I learned about buying aluminum rods for some weird engine is that it is a good idea to see how close the stock rods come to hitting the cam. As in a GMC the OEM rods are very close to the cam and you must jump through all kinds of hoops to use aluminum rods. Reduce rod jurnol to SBC size and get small base circle cam ground. I decided steel rods were a better choice.
  3. Bullington
    Bullington
    I have ones that say Cadillac in big block letters. The cursive script ones are cooler ;)
  4. 38FLATTIE
    38FLATTIE
    from Colorado
    I'm not picky! Wanna sell them?
  5. RichFox
    RichFox
    Now if you decide that those big bulky aluminum rods will clear your cam, bottoms of the cylinder bores, pan rails and counterweights it's time to think about what else they can do for you. Since you would be having them made anyway how about calling your piston supplier of choice to see what he has on the shelf in a flat top blower piston of around 3 1/2 inches. 2 liter Pinto comes in at 3.570 and when I was running a Pinto they were off the shelf parts. Some guys were running big boost in these things. it's still a race motor. And you get a good ring pack with the wrist pin up high for good rock control. Nice light ***embly. Measure the pin to crown hight and the same for your stock Cad parts and add the differance to the rod lenth so the piston comes up to "0". While we are at it how about some reasonabley avaible rod bearings. You could grind those way oversize rod jurnols down to 2.750 (440 Dodge) or 2.200 (BBC) and loose some bearing friction and gain good easy to get bearings. Wont cost any more to make your rods fit a BBC bearind. maybe less.
  6. 38FLATTIE
    38FLATTIE
    from Colorado
    The journals are 2.46" stock. After working with GRP for rods, it was determined that a journal diameter of 2.1"(SBC large journal) was needed, to get the rod width where we needed it to be. Mile High Crankshaft said it can be safely done, and will handle the work, and re-hardening.Bore will be .040" over(3.5376")
    Ross will make short(compared to stock) forged blower pistons, and the rods will be lengthed .1875", or .25",plus the difference in pin relocation, depending on how much materal we need to take out of the heads for valve clearance, and still keep it under 375 CI.
  7. RichFox
    RichFox
    They don't much care what you take out of the heads. It's strictly a bore and stroke deal. What is your bore going to be? 2.1 is even better for rod jurnols.
  8. 38FLATTIE
    38FLATTIE
    from Colorado
    They don't measure displacement? Just bore and stroke?
    If we can use SBC small journal rods, it will be even better. Waiting to see what Mile High Crank says.
    If we can,, we'll stroke it .25", and bore it .040" over.
    Total will be 3.5376" X 4.75"
    373.5 cubic inches. Big flathead, huh?
    If we have to use the SBC large journal, we'll bore it .060 over, and stroke it .1875"
    3.5576" X 4.6875"
    372.8 cubes.
  9. RichFox
    RichFox
    SCTA computes cubic inches as Bore times bore times .7854 times stroke times number of cylinders. Nothing else. A 4 and a half inch stroke seems like enough to most people. My Plymouth was 4 3/4. I am glad you have decided to use iron heads.
  10. 38FLATTIE
    38FLATTIE
    from Colorado
    I posted this on my build thread, but I'll post it here for you Flatcad guys!
    I spent the day at a CAD modeler/digitizer, and now have improved, high compression, two piece heads in a CAD prigram. I thought it was pretty cool.
    The purpose is so that I can try different chamber designs, to see what flows the best.
  11. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Looks great Buddy. Can't wait till you get em done. That takes alot of work, Cool to see someone else doing em as well.
  12. 38FLATTIE
    38FLATTIE
    from Colorado
  13. Any updates on the heads?
  14. 38FLATTIE
    38FLATTIE
    from Colorado
    What do you mean?
  15. I was just wondering if your were able to get a set that flows well and if you were having any luck getting them made up?
  16. 38FLATTIE
    38FLATTIE
    from Colorado
    I can get them made no problem, but we are still working on a new chamber design.
    You weren't by chance, volunteering?;)
  17. Bullington
    Bullington
    Here are the script heads that I have.
  18. Bullington
    Bullington
    The exhaust manifolds were modified as the engine was in a Cord.
  19. 38FLATTIE
    38FLATTIE
    from Colorado
    <HR style="COLOR: #e5e5e5; BACKGROUND-COLOR: #e5e5e5" SIZE=1> <!-- / icon and ***le --><!-- message -->
    Even though the Lasalle is gone, you can follow the engine build here:
    http://www.jalopyjournal.com/forum/s...d.php?t=496866
    I promise you'll see the most advanced, and powerfull Flatcad EVER built! No B.S.!
    <!-- / message --><!-- sig -->
  20. 38FLATTIE
    38FLATTIE
    from Colorado
    <HR style="COLOR: #e5e5e5; BACKGROUND-COLOR: #e5e5e5" SIZE=1><!-- / icon and ***le --><!-- message -->
    Good news! The FlatCad Racing support shirts are now available!
    These are designed by Dart165 and Keeper, and printed by Oddrodgarage. Thanks guys!
    C'mon, you KNOW it's a good cause!
    http://www.flatcaddy.com/products/list.php
  21. 38FLATTIE
    38FLATTIE
    from Colorado
    I know this thread is old, but I had to show these off!
    How about cast 4-71 blower intakes, for the Flatcads? These are soooo cool, and this is the prototype!
    You know you're gonna want one!:D
    I'm not the one making them, but I can get you set up with the guy that is!:cool:
  22. captainjunk#2
    captainjunk#2
    holy carp !! that flatty caddy with a blower is some shweeeet garage eye candy , thanks for posting the pics of this creation
  23. llonning
    llonning
    Damn, those look good!!!
  24. 38FLATTIE
    38FLATTIE
    from Colorado
    Sounds like a limited few of these will be available in a couple of months!
  25. emiliedk
    emiliedk
    from denmark
    Buddy!!
    you know i need one...
    -palle
  26. 38FLATTIE
    38FLATTIE
    from Colorado
    Palle, I p***ed your info along, and will let you know when they are done!
  27. Flatred53
    Flatred53
    from Sweden
    COOL!!!! I’m impressed, looks great!
  28. 38FLATTIE
    38FLATTIE
    from Colorado
    I thought I'd show you guys the heads that Keeper just finished for the FlatCad. He does amazing work!
    These heads have 7 extra stud bolts, to help handle the blower compression.
    Hank37 likes this.
  29. strombergs97
    strombergs97
    Those heads look like Norm Fricks, two part for a Ford Flathead V8..
    Those are a work of art. Nest is how will they perform..
    Looking good Buddy..
    Duane..
    see you at the SALT
  30. 38FLATTIE
    38FLATTIE
    from Colorado
    Well, with John's help, I had a set of Norm Frick Caddy Heads!:D
    See you in August Duane!
