Please ID this motor and tranny!
Discussion in 'The Hokey Ass Message Board' started by J Early, Nov 8, 2010.
  1. J Early
    J Early
    Olds rocket motor with centerbolt covers. Any idea on year, details? It appears to have about a 3.9" bore.
    Thanks!
  2. Olds
    303 3-3/4" bore
    324 3-7/8" bore
    371 4" bore
    394 4-1/8" bore
  3. The ****** is a slant pan hydro. And it doesn't have 394 heads.
  4. F&J
    F&J
    The valve cover style and the carb style looks to be the last version of the 303.
    I think on the " Olds Rocket thread" there should be numbers of the head and blocks to get the exact year.
  5. RichFox
    RichFox
    I think it's a 324. But maybe a 303. If it's a 324 I guess that makes it a '56? 303 maybe a '55?
  6. F&J
    F&J
    Rich, you are right again, it shows to be a 54 324 in the chart on the Olds Rocket big thread:
    I "think" the pics he posted shows head number 7?
    Cut and paste:
    year: cui: block#: head#:
    1949 - 303 cui
    1950 - 303 cui
    1951 - 303 cui
    1952 - 303 cui
    1953 - 303 cui
    1954 - 324 cui #7
    1955 - 324 cui #8
    1956 - 324 cui #10
    1957 - 371 cui
    1958 - 371 cui
  7. Never2low
    Never2low
    '53 or '54. At first I thought '53 (303), but they might be #7 heads, ie '54 (324)
    Paul will chime in, he knows everything. :p
  8. RichFox
    RichFox
    It's been such a long time since i have had an Olds. I had a '54 in '63. A kid in a '55 Merc rear ended it just after getting all the panels straight and painted. I guess it went to the crusher. I bought a new Pontiac and never looked back.
  9. J Early
    J Early
    Would there be a #7 stamped on the heads somewhere?
    Are there #'s on the block that can be decoded?
    Thanks
  10. 40fordtudor
    40fordtudor
    i agree--303 olds. we put one in my 51 shoebox back in 1959
  11. 40fordtudor
    40fordtudor
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I can see the 7 from here in the first picture.
  13. Rocky
    Rocky
    Classified Editor
    I see it too...makes the heads 1954 Olds 324.
  14. J Early
    J Early
    I know this motor was hot rodded in the '60's with solid lifters. Could the heads have been swapped? I hear all the heads are interchangable,303, 324, 371,394...
  15. F&J
    F&J
    Sure, they could have been swapped.
    The late DON_WOW posted all the block numbers somewhere on a thread. Maybe do an advanced search and look for his posts on block numbers.
    I wonder why they would call it hot rodded with a 2 barrel? I suppose if they started with a 303, adding the later 1.8 ratio rockers, a solid cam, and then using the 54/55 heads with much larger intake/exhaust ports, you would see a good change in HP over a stock 303. Also, a 303 would have had the intake manifold with much smaller ports, so when switching the heads, they should have also used the 54 intake, too.
    I'd pull a valve cover to see if it really does have solids. Look for adjustable rocker arms , rather than the stock non-adjustable arms.
    If it does not have those adj rockers, it likely is just a stock 324. Just my 2 cents.
  16. F&J
    F&J
    I found the thread with advanced search from DON_WOW.
    copy and paste:
    Engine ID numbers
    1949--8A1001 TO 8A193864 H PREFIX=HYDRA MATIC
    1950--8A194001 TO 8A568689 H PREFIX= HYDRA MATIC
    1951--8C1001 TO 8C287312 B PREFIX= SYNCHROMESH
    1952--8R1001 TO 8R214478
    1953--R215001 TO R549482
    1954--V1001 TO V355083
    1955--V400001 TO V983275
    1956--A001001 TO A385513
  17. J Early
    J Early
    Cool, thanks!
