double hump heads with a shaved off corner?
Discussion in 'The Hokey Ass Message Board' started by 2-TONED, Nov 6, 2010.
  1. 2-TONED
    2-TONED
    aug 64 -- casting #3782461.
    both heads front and back have the side of the "double humpies" machined off???
    whats up with this anyone know?
      174.7 KB
      184.5 KB
      172.3 KB
      191.4 KB
  2. fitzee
    fitzee
    Head can be from 62-67 327 194 intake 1.5 exhaust. By the years it could be vette. The marking?? I have no idea. might be a clearance issue on something.
  3. Deuces
    Deuces
    Might have been a clearance cut for something... For what? I don't know.......
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Someone in the past did it to tell which was the front and back since there done on opposite ends. Why, just because.
  5. fitzee
    fitzee
    Would there be a X after that number?? Seems there was two sets of heads with this same number. one with a X and another without. The X head was Hi comp (57.5cc), best ports of any OEM production cast-iron head, intake runner vol 170-180cc while the one without was Similar to 461X but with smaller intake ports. They say they were know to crack!!
  6. wrench409
    wrench409
    from Here
    My sneaky cousin used to modify double hump markings to make them appear as PP heads. He was very good at it. He always refused teardown at protests.
  7. Shiftee
    Shiftee
    I have seen many pairs with that done to them. Not sure the reason but I also wandered why?
  8. NWRacing
    NWRacing
    my circle track buddies do that to make them "non double hump heads" if they aint cheatin they aint breathen!
  9. Ebbsspeed
    Ebbsspeed
    Read it again Johnny. He said both heads, front and back.......
  10. brandon
    brandon
    canadian...?
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Don't have to now :D.
  12. draggin'GTO
    draggin'GTO
    Looks like a machining error made while facing off the ends of the heads on the GM production line, nothing more.
  13. joel
    joel
  14. bonebroke
    bonebroke
    from WI.
    hump and, a halfs. theyre junk, ill take them off youre hands:)
  15. k9racer
    k9racer
    over the last 40 years I have machined off the humps off over 50 heads so no one could easly tell what heads I had on my engines. Some short tracks made them illegal so you had to hide what you were running. I never sold any of my parts so it did not matter to me. Plus it took about 4 on. off the engine. the last part was to be funny.. later Bobby..
  16. 2-TONED
    2-TONED
    forgot to add each head has this tag on the side.
    GUARANTEED VOID IF REMOVED.
      150.7 KB
      175.1 KB
  17. 2-TONED
    2-TONED
    theres no X after the casting number.
    its a complete dates all jive. (heads block intake) 64 dated 327 from a 65 impala convertible.
    250 HP. Powerglide.
  18. Deuces
    Deuces
    It could be a tell tale mark done by a shop that re-manufactured (rebuilt) those heads... That's gotta be it!!
  19. harrington
    harrington
    from Indiana
    The little tag is a re-man tag put on by the re-man company.
  20. Fast67VelleN2O
    Fast67VelleN2O
    This guy nailed it. I have seen plenty of 461 castings machined like this. They aren't anything different or special from other 461 castings.
  21. Fast67VelleN2O
    Fast67VelleN2O
    Just to dispell some myths that people hold about these heads.....
    All 461 heads cast before July of 1963 are X heads. Not all X heads had the X after the casting number. Some heads had the X cast into the bottom of water jacket on the underside of the cylinder head. ALL 461 X heads had a 62cc chamber. ALL 461X heads had 1.94 valves.
    Heads cast after July of 1963 were just standard 461 heads. They were not X heads.
  22. uriahjackson
    uriahjackson
    Those tabs are heat tabs to tell if the head has been overheated. The machine shop that did the work on them is protecting their own intrest. The circle in the middle of the tab will turn color if heated, thus voiding the warranty.
  23. burnout2614
    burnout2614
    chevrolet used many different cast marks and even they could'nt tell exactly what was what even though many guides exist that show what the marks are supposed to mean. peace
  24. 2-TONED
    2-TONED
    OK THANKS for all the info.
    this is the 4th complete 250/275 hp 327 i own 2 im running in cars. this ones headed out for a freshen up.
  25. mike shults
    mike shults
    from auburn ca.
    for some reason,most of the markings i've seen like that have been in marine applications. anyone seen the same?
  26. 56sedandelivery
    56sedandelivery
    It's difficult to see in the photos, but is that truly machined off, or could it be casting mold flaws? I've NEVER seen any that looked like that. Someone else was right, the tabs are overheat indicators for warranty purposes. Someone else wondered, "Canadian"; usually Canadian heads say Canada, cast in the valve/spring/rocker arm area. In the tech section, you will find a post about camel humps/double humps/fuelie heads, by FWilliams, but he used to have a different handle. Maybe he'll read this post and contribute. Butch/56sedandelivery.
