How do I keep bare panels from rusting
Discussion in 'The Hokey Ass Message Board' started by jimvette59, Nov 10, 2010.
  1. jimvette59
    jimvette59
    Hi, to every body this message board is unbelievable. I need some advice. I haven't been able to keep new panels from rusting, just my hands start the process. How do I reverse it and keep it from rusting. I see many bare bodies on this message board (cars I mean) bodies with no paint on them while being worked on. How are they kept that way.
  2. lakeroadster
    lakeroadster
    from *
  3. nightperson
    nightperson
    i use mineral spirits and oil mixed 1:1- this is the cheapest and a good lubricant if you need to work the panel as far as any metal shaping- the mineral spirits cleans the panel a little too when you wipe it down. atf is also good, use anything as long as its not silicone based
    i 1st used oil and kerosene but it doesn't smell the best but works just as well
  4. 54HotRod
    54HotRod
    I saw a thread yesterday about this same type of thing and Gibbs was the most used and highest rated item that people use for this type of thing. I din't really know what Gibbs is or where to get it, so this information might help me out too.
  5. GIBBS is the best.
  6. mgermca
    mgermca
  7. GreggAz
    GreggAz
    you will want to get the oils from your skin off the metal as soon as possible. Some people (me included) just cause metal to rust. if you touch the bare metal clean it wit mineral spirits, or other cleaner, and oil it with your chosen protection.
  8. BOWTIE BROWN
    BOWTIE BROWN
    hey lakeroadster , i love your stand in front of them . God bless america . Freedom is'nt free.
  9. big bad john
    big bad john
    .........I use Gibbs......its a little expensed,but my time is worth something too....
  10. Another Gibbs fan here in NZ.
    Don't put it straight on the metal.
    Put it on a rag then rub on the metal.
    It will go twice as far doing that.
  11. pauls fords
    pauls fords
    Captain Lee"s from Master Series will desolve any surface rust and leave a coating of zinc chromate,,,,Have body parts in storage for years,,,,no rust,,,,about $30 a gallon,,,,you will not be dissapointed...
