Painting headers?
Discussion in 'The Hokey Ass Message Board' started by johnybsic, Nov 10, 2010.
  1. johnybsic
    johnybsic
    from las vegas
    Hey guys.
    Ive got a set of fenderwell headers, In raw steel...Which wont look good for too long.
    As far as painting um
    ive searched around and gotten some good recomendations on header paint.
    But what is the procedure for doing this?
    Just wipe um off and spray? or what.:confused:
  2. badgeree
    badgeree
    I used POR-15 paint on my Block Huggers. Sandblasted, paint with a brush. I did the whole twin exhaust, incl. mufflers. You have to fire up engine pretty soon and the heat cures the paint. Do it outside, because the ****** smoke it causes filled my garage for about 10 mins. The POR-15 is the best heat proof paint I, or any of my mates have ever used. Friends have used it 6 or more years ago and pipes look like they were painted yesterday. If you are going to use it, buy a small tin, it goes a long, long way.
  3. thebronc4019
    thebronc4019
    from New Jersey
    I have gotten good results by sandblasting them and then immediately spraying them with Eastwood High Temperature Exhaust Coating. I buy it in the pint sized can and spray it out of a conventional siphon spray gun. I thinned it a bit with xylene I think. The directions are on the can. I sprayed two coats on some exhaust components and the stuff has lasted for years.
  4. johnybsic
    johnybsic
    from las vegas
    Ahh yes...Sandblasting, God i thought i was done with you! at least for a while:rolleyes:
    Makes sense. never thought about having to "Cure" or bake the paint, considering my engine aint gonna be ready to fire for a while i guess ill hold off, but good info to know. Ive heard good things about the Por15, Good things indeed.
  5. I've always had good luck with black BBQ paint. Install them and run the engine for a few minutes, then let them cool down and rub the tubes with a newspaper. Then run the hell out of them. I'm too cheap to buy header paint.
  6. bbc 1957 gasser
    bbc 1957 gasser
    bbq paint works ok .the best stuff ive used is por 15's cast grey manifold paint then id say eastwoods cast grey manifold paint
    vht paint is junk dont waste your time or money
  7. tommy
    tommy
    I've had good luck with Eastwood's brush on stainless steel header paint. I bead blast them first and then use a foam brush usually 2 coats.
  8. gofaster
    gofaster
    from georgia
    I have a set of fenderwell headers on my BB 56 Chevy. Sand blasting would be the best for adheasion. I hosed mine down with brake cleaner and let them air dry for an hour then shot them with white VHT header paint. If you follow the directions on the can for curing the paint (it is very specific) you will have a coating that will not burn off. I painted my headers three years ago and they still look great, minus the bugs and road debris that you get with a set of white headers being directly behind the front wheel. I have even spilled brake fluid on them and it wipes right off without damaging the coating. Good stuff, cheap and easy to touch up if you have too.
  9. Blast em with aluminum oxide media. I like the VHT coatings >>>>.
  10. lawman
    lawman
    What 4019 said.Tom (Tired Old Man)
  11. ajwhiskey51
    ajwhiskey51
    I had mine powder coated, they lasted about 2 weeks before flaking off.
  12. Jimv
    Jimv
    POR-15, i've tried everything and its the only paint that lasts
    JimV
  13. hellcat666
    hellcat666
    we had a set powder coated at the resto shop i work at just to see what would happen. month later i had them in the sandblaster and we put the eastwood stuff on them it seems to be working pretty good eastwook makes some nice products. would like to try to POR15 stuff though and see how that looks.
  14. hotroddon
    hotroddon
    X2
    If you are going black, consider getting them coated in Metallic Ceramic Black Coating. It lasts longer then paint and holds the heat in the header creating better exhaust velocity while keeping the outside air temp down.
  15. hotroddon
    hotroddon
    Powder coating is NOT heat proof and always burns off. Metallic Ceramic is the only way to go.
  16. Get 'em bead blasted prior to paint. Then wipe 'em with MEK and squirt the paint on 'em.
  17. yruhot
    yruhot
    Johnny, I used a #m scratch pad on my new headers,wiped down with laq.thinner,Let dry a good hour, then hit it with several LIGHT coats of VHT paint I used white but I used light coats no runs and I've been running around for a couple of months and no problems. Leaked some brake fluid on then and it wiped off. Took like 3 cans at like $100.00 per can I believe. Something like that but I think being on a tight budget I believe that not too bad. Just don't lean into them while trying to set the timing and turning the dist. You'll have a weinie roast in your pants. Don't ask me how I know.lol.YRUHOT.....Doug
  18. yruhot
    yruhot
    Johnny sorry for the typo that should be like $10.00 per can of paint. YRUHOT.........Doug
  19. Stevie Nash
    Stevie Nash
    I sandblasted then painted mine with white BBQ paint. Says it holds up to 2500 degrees. They look great, but I haven't run the engine yet.
  20. dallas1
    dallas1
    this por15 stuff does it come in diff colors or just black?
  21. spikeshotrods
    spikeshotrods
    I had mine sandblasted then went over them with 120 grit sandpaper to smooth them out a bit then sprayed them with VHT header paint, followed the directions on the can for curing process. Never had any problems with blistering or flaking I even got caught in a rain storm last week for about miles week and the cleaned up fine with a little scrubbing.
