All right, we americans have big ****'s, every seat I have looked at in the junk yars are 20 inches wide. I need 2 seats that will be no wider that 37 inches for my '28 Es***. Any recommendations.
chances are if you're not going to a vintage junkyard everything you find is going to be 20" - 24" wide. Your best bet is trying to find what i've always known as a "jump seat". Came in a lot of vans, coe trucks, ect. just a simple hoop frame and springs or foam, no recline, usually no sliders, but they are generally 18" wide. They look at home in an early car too. I'll see if I can find a pic. edit: this is a Wise seat for a boat its 18 1/2" wide similar to the style i was talking about but with an exposed hinge for folding down. They are about $75 a piece which is pretty reasonable for a new seat.
What about Miata or S2000 seats? I would think they would be on the small side. It would take some work to make them look at home, but I think most late models would.
My Es*** had Pinto high-back buckets in it when I got it. They fit fairly well. I replaced them with a bench from a Dodge Caravan.
