I need help please - hinge pins
Discussion in 'The Hokey Ass Message Board' started by MGK, Nov 11, 2010.
  1. MGK
    MGK
    from Ohio
    Fellas,
    I have two hinge pins that I cannot get out. The car is painted first off. I have tried using a c-clamp with a socket, hitting with a BFH and drilling. I have not found a drill bit yet that can cut thru these damn pins. Any ideas are appreciated as I have lost my mind with **** and am about to step in front of a moving semi truck and call it a day.
    Chris
  2. terry48435
    terry48435
    I've seen a hinge pin removal tool some where. If I can find it I'll let you know.
  3. billthx138
    billthx138
    unfortunately, you are going to have to heat the hinge and then knock out the pin. Been there, done that, ruined hinge pin removers, drill bits and busted knuckles.....heat was the answer.
  4. terry48435
    terry48435
    Mac's auto parts have a pin remover.They're about $25.
  5. bobj49f2
    bobj49f2
    First, I'm ***uming you're talking about an external type hinge like on a '40s Ford truck. I've had luck drilling from the top, starting with a small drill to make a center hole, then progressing to a larger drills until you get to a drill the same diameter as the smaller diameter of the pin. Drill down deep enough to get p*** the knurled upper part of the pin and take a drift and knock the pin down through the bottom.
    I've heard the pin removers work like **** and tend to bend and break.
  6. hotrod40coupe
    hotrod40coupe
    Bob Drake has a hinge pin remover that works well. Just soak the pin with PB Blaster first.
  7. MGK
    MGK
    from Ohio
    Thanks fellas for the help. What's the best way to heat them up?
  8. falconsprint63
    falconsprint63
    from Mayberry
    drake's tool works fine. when/if you bend the included pins just cut off a grade 8 quater twenty and round off the ends. works the same doesn't bend as easily.
  9. sawbuck
    sawbuck
    from 06492 ct
    air chisel... grind the chisel down till it fits the pin size...a little pen oil and take your time ....
  10. 117harv
    117harv
    Heat them up red and let them cool abit so when the BFH and the punch go to work the hinges won't bend. Wet rags to minimize paint damage. I have been where your at and i feel your pain but you did give me a laugh with your first post.....good luck
  11. Francisco Plumbero
    Francisco Plumbero
    from il.
    Drakes tool works fine on a pin that is not frozen in, same as all of the others, it works well on unfrozen pins, it's not magical. On a painted hinge I would soak it heavy with something that will not toast your paint, there is a knurl on the top of the pin that's about 3/8" tall on most pins, that part locks it, take a good high quality bit and drill down about 3/8" to eliminate this knurls strength, progressively widen the hole until you have it weakened soak it as much as you can and then use a pin tool, if she won't go don't force her to death of tool occurs, just soak more, drilling them all the way out is a beach, you most likely will trash the hinges, be patient. It's still not easy to heat them out so exhaust all possible soaking.
  12. OGS41
    OGS41
    I scored the paint where the pin was painted in place. Put the hinge pin remover on and applied pressure then with rag, soaked with PB Blaster. Every night after work I would check h/p remover and adjust for more pressure and soak a little more. Took several days but finally came loose-no paint damage.
  13. Matt Madison
    Matt Madison
    Ive found on stuck pins and bolts if you take an engraving pencil and vibrate the itenm for 5-10 minutes it normally comes free for me just a suggestion
  14. RB35
    RB35
    Soak pin with your favorite liquid wrench, blaster, etc., every day for 3-4 days. Tape cardboard to door under the hinge, usne pneumatic chisel with pin point on bottom of hinge pin, maybe drill small pilot hole to keep it centered. Push up on chisel against pin and pull, then release trigger a few times. Resoak and try again the dext day. Popped all the pins in the '35 that way. Don't ask why I now suggest cardboard first.
    RB
