Vinegar to remove rust? Old guys rule!
Discussion in 'The Hokey Ass Message Board' started by HELLBILLY, Aug 11, 2010.
  1. HELLBILLY
    HELLBILLY
    To say the least I didnt believe this but it worked!
    I got a Moroso drag race pan with an old 66 Nova drag car along time ago.
    Was just gonna buy a new pan but was put off by the price of a new one......DAMN!
    It was rusty inside then and was even worse now, so i think media blast it?
    Guy at the blaster says nope, it has a trap door in the bottom for oil flow and he didnt wanna have no part of it, ****.
    So i try wire brushing it....... didnt work, way to much rust (and im a lil lazy! lol)
    The 88 year old car guy next door to me wanders in while im going at it with the angle grinder, he looks at me and says why dont ya just put it in vinegar?
    I was like old man...... aint no time for joking :D
    He goes on to tell me he always did this years ago, said it works on tools too.
    So off to store we go, get 3 gallons of distilled vinegar at $2.00 a pop (cheap stuff).
    Put it in a rubbermaid plastic tote, drop in the pan top first.
    He says I have to leave it alone, cant pick at it like a scab he says.
    Get back from NSRA Louisville after 3 days and yank the pan out.
    I couldnt believe it! Clean bare metal 4 inches down inside and out.
    CLEAN BARE METAL:eek:
    So I flip it and fill it up inside, wait a few more days, CLEAN BARE METAL!
    No s****ing no nothing! lol
    The lil rusty stains you see in the pics wipe right off with a rag. UNREAL.
    I'm still amazed, we gave it a baking soda bath, some WD40 and i have to say im still smiling! lol
    I had NEVER heard of this, so i just wanted to p*** this along to anybody else.
    Dont ever discount the old guys, they ****in rule! :)
    Oh yea, whole damn place smells like Summers Eve now...... LOL
    dana barlow likes this.
  2. 61TBird
    61TBird
    <object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/eGblsNXkJog?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/eGblsNXkJog?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
  3. ZRX61
    ZRX61
    from The AV
    Great, now I feel old.. ya rat ******* :(
    :cool:
  4. Dr.Slam_Jessies_Customs
    from Las Vegas
    wow i have had an old guy tell me this trick but he was one of those old guys that also use to play a lot of pranks on me so i never did it thinking it was another prank. cool to see it worked for you
  5. ClayMart
    ClayMart
  6. dumprat
    dumprat
    from b.c.
    I have used it on a lot of rusty stuff, guns for instance. Just don't soak cast iron or aluminum in it. It eats it.
  7. Sugarskull
    Sugarskull
    from Calgary
    I would have never guessed it to be strong enough. Yay! I'm pretty sure I can find some rusty stuff to try this out on. Thanks for the info.
  8. mj40's
    mj40's
    I have been soaking old cast iron Dutch ovens for years with no problems. Taught cooking cl***es for 18 years and that was my recommendation too.
  9. ZRX61
    ZRX61
    from The AV
    Electrolysis is more fun.. especially when ya add lye to the mix....
  10. Jimmy Tee
    Jimmy Tee
    Cool Trick.
    So what is better for cleaning up water jackets in an Engine Block, Mol***es or Vinegar?
  11. RAY With
    RAY With
    Yep-One of the old guys here that has used vinegar for 55+ years and it really works well as indicated by the above pictures.
  12. Jimbo17
    Jimbo17
    Sounds like a cool trick and well worth trying.
    What should I use to clean up the collector tube area of a set of ****** Headers.
    When the headers were knew they were coated right out of the box but the collectors always seem to get rusty no matter what I have tired to stop it from happening.
    Other then the wire brush and a lot of hard work is there any product you can spray on them to remove the rust?
    I know vinegar eats aluminum but it might be worth a try.
    Jimbo
  13. chuckbob
    chuckbob
    The reson why it works is because Vinegar contains Acetic Acid. The Acetic Acid is what cleans the metal parts. You can actually disolve steel wool and nails in it if they sit in it long enough. Just make sure you rinse it off afterwards. FYI: you can make wood stain and lether dye from soaking steel wool in a mason jar filled with Vinegar. It takes about 2 weeks to create the stain.
  14. skyrodder
    skyrodder
    i finally got off my *** and tried it.. soaked 1 piece for 3 days in regular ol vinegar and then rinsed it off with water and a little scrubbing with an sos pad, Thanks H.A.M.B!
  15. Beebeebobby
    Beebeebobby
    from Webb City
    Guess what it works on old coins...too....just sayin'
  16. K-88 ghost
    K-88 ghost
    from Nevada
    In the process of restoring a V/W that I picked up in the bay area, it had been over there in the Vallejo area for about 38 years most of the engine sheet metal was heavy with rust, went the vinegar route and like the man says leave it alone, I let the tin soak for over a week and it came out with little or no rust and most of the paint came off when I pressure washed it.:cool:
  17. 23crate
    23crate
    from nz
    theses a book that suggests all sorts of uses for vinegar ...
    ive been bodyman for 30ish years ,, and this is new to me,,, i might be forced to go find a rusty thing and some vinegar .......
    wanders off to the garage....
  18. ytt49
    ytt49
    from socal
    wow that is so cool and cheap perfect for us budget builders.
    thanks again H.A.M.B
  19. Oh man, That's awesome!
    How can i soak panels that are surface rusted though?
    I was thinking of getting a rag, Soaking it in vinegar, and leaving it on the boot lid for a test perhaps?
  20. johnybsic
    johnybsic
    from las vegas
    Full of win!
    ive got some extra baking soda too! clean parts and awsome volcanos in the workshop
  21. sololobo
    sololobo
    Nuthin like old dogs learning new tricks. My wife uses the stuff to kill weeds all summer, works fab, careful kills gr*** as well. And most of us have seen the young man use vinegar on the cute girls jelly fish stings in the car ad!! ~Sololobo~
    henry's57bbwagon likes this.
  22. K-88 ghost
    K-88 ghost
    from Nevada
    I think putting a shop rag on a spot and make sure it stays wet with vinager for about three days should give you an answer:cool:
  23. Runt Rodder
    Runt Rodder
    from Virginia
    vinegar and baking soda awesome as a cheap drain-o. Used it a few times in old houses when i was in the handyman business
  24. big creep
    big creep
    man i love the hamb!!! i learn stuff all the time!
  25. Wheelie
    Wheelie
    from Dallas
    You can also drink it and throw up a lot.
    A-10 Mech and 58oldsmobile88 like this.
  26. I just need to find a big enough container to soak my winshield frame hinge in to get the rust broken up so I can use in now.
  27. OahuEli
    OahuEli
    from Hawaii
    The HAMB never fails to amaze me! Never heard of the vinegar or mol***es tricks.
    My brain feels kinda rusty sometimes, maybe I should soak my head in vinegar...:rolleyes:
  28. zmandet
    zmandet
    Well guys I'm 2 days into my science experiment, I have a 35 gallon gas tank from a 62 M***ey Ferguson Farm Tractor, it had been left with gas in it for several years, and it was very rusty and gooey inside. I cleaned it out and invested in 20 gallons of distilled vinegar. So far it appears to be working out. I am planning on letting it go for 3 or 4 days and then seeing what it looks like. I really appreciate all the ideas that I've heard and found on this site!:)
  29. 2manytoys
    2manytoys
    from Fresno
    I have been using Muratic Acid to remove rust on fender and body parts. (Yeah I know, they say dont use it cuz its dangerous, and thats probably why I do. I always a was rebel). Problem is on the larger parts the solution dries out and doesnt clean well even when I keep getting it wet. I started using old rags and hang a plastic bottle over the top with a small hole punched in the bottom so the acid slowly drips out and keeps the surface and the rag constantly wet with acid. The acid is nasty and the rags burn up real quick. I usually hold my breath and wear goggles and gloves when I work aound it. I think I will switch to the vinegar and try it. I'm getting too old to keep getting hurt.
  30. plym_46
    plym_46
    from central NY
    mol***es is an acidic food similar to citric acid, vinegar is acedic acid, phosporic acid works, and muriatic is buffered hydrochloric acid, they all work by disloving the oxidized layer. vinegar is safer, easier to dispose of and cheaper. Just takes longer to work than the stronger acids, and probably does not cause as much brittling of the metal as the stronger ones.
    I have friend that does lots of automotive restoration work, he has a half 55 gallon plastic drum filled (cut horizontally) with vinegar which he uses for soaking parts and hardware.
    razoo lew likes this.
