Looking for something different to power my 34 ford Truck
Discussion in 'The Hokey Ass Message Board' started by dirty4, Nov 10, 2010.
  1. theHIGHLANDER
    theHIGHLANDER
    I'd put in a SBC and make an air cleaner that looked like a can of worms. Ok, just kidding:D
    You won't find anything on this board that will be different for the sake of different. We're all "different" in our own way. There's several Nailheads, Olds, Caddy, early Hemi, and Flatheads here. All of em different than the gratuitous "crate motor" logic. Frankly I think it ought to have anything, ANYTHING, but a small block Ford in it. They weren't even around in the time of the early hotrod and I hear the "Ford in a Ford" cliche more often lately. It's like fingernails on a chalkboard to me. In the end I think your individuality would shine through in how whatever you use is dressed and detailed. I'd advise you don't get so wound up in different that it steals from your gig.
  2. FINKSTR
    FINKSTR
    I'm putting a '63 409 in my sedan for the same reason. I nice mult carb'd straight 6 would be cool.
  3. Rcraft
    Rcraft
    from cypress tx
  4. tommy
    tommy
    That is the reason that I bought my 334 P/U.
  5. Bert Kollar
    Bert Kollar
    All my rods have Mopars in them . I build them properly and they are BULLET PROOF and powerful
  6. fab32
    fab32
    Now your talking. To take it a step further and put a pair of Corvette valve covers on it and a alluminum intake/4 bbl carb. Anything more will just be showing off.
    Frank
  7. Revhead
    Revhead
    from Dallas, TX
    stude V8, packard V8, Dodge 318 poly, Mercury 383, Jeep tornado OHC engine... different but also expensive
  8. A 63 Chevy II 4 Cyl. with 12 to 1 compression, with a built power glide. Really wild, I had it in my roadster.:eek:
  9. brucer
    brucer
    from western ky
    ford 2.3 liter 4cylinder with 5 speed...
  10. 73RR
    73RR
    Hhhhmmm, if you use what everyone else is using then it won't be different....
    As far as engines go, different could be a Jag 4.0/4.2 DOHC 6, or a NorthStar, or a Toyota 4.7, and that Dodge v-10 can be found in plenty of beat up pickup trucks.
  11. What do you like? What can you afford? Don't use what others want you to use. Put in it what you can work with. I like Y-Block Fords but if you don't know much about engines use an SBC, plenty of support out there for them and their easy to work on.
    "Trust your own instinct. Your mistakes might as well be your own, instead of someone else's." ~Billy Wilder
  12. Master of None
    Master of None
    I'd say put a Ford in a Ford (I'm running a 289 in my 34). But since you wanted different I would say 331 Chrysler Poly motor, they look cool.
  13. Wild Turkey
    Wild Turkey
    For just a few more pounds you can get a 478!!
    305A = 738 lbs.
    305B = 771 lbs.
    305C = 840 lbs.
    305E = 795 lbs.
    351 = 860 lbs.
    401 = 880 lbs.
    478 = 925 lbs.
    Torque?
    478 -- 442 @ 1400 rpm
    305 -- 280 @ 1600 rpm
    My 401? 377 @ 1400 rpm
    And those are 1960's GMC numbers, who knows what they really make?
    cid -- bore - stroke
    305 -- 4.25 in. - 3.58 in.
    401-- 4.87 in. - 3.58
    478 -- 5.125 in. - 3.86 in
    Interesting thing is they used the same external block size for all displacements!
    And then there was the "twin-Six" V-12 -- 702 cubes, torque 630 @ 1600-1900, weight = 1485 lbs. :eek:
  14. If you go with a Jimmy V6 better beef up the springs. :rolleyes:
  15. big bad john
    big bad john
    .......... go with a deckout Flathead.....Coolest is always better that different.........
  16. samurai mike
    samurai mike
    i have a 354 mack flat head i'm not using!
  17. mopar210
    mopar210
    ok ill play . one of these .
  18. guitar man
    guitar man
    from Tulsa OK
    I wasn't serious about the 345, that was supposed to be humor :D
  19. rustydusty
    rustydusty
    How about a 300hp Mercury v8 outboard motor mounted horizontaly! Lightweight aluminum, 2-stroke power but you would have to fabricate a manifold to level out the side draft carbs. This is a pre-fuel injected, pre-4-stroke engine. I always wanted to try this with a front engined hydroplane! Now that's different!
  20. greaserzombie
    greaserzombie
    Just do what a buddy of my dad's did in high school, put a 348 in it with a nasty cam, and TELL everyone it's a 409. Cheap and fun.
    And come on... I had a buddy with a wacked out 345 in his scout, they're heavier than hell, but they are wayyyyyyyyyyy different.
    Or what the hell,go with an Infinity 4.5, it worked for Boyd..........
    Seriously though, I love slant 6's. Not a ton of power stock, but they are damn indestructable. Semi traditional too.
  21. HarryT
    HarryT
    I put a nailhead in mine.
  22. SQUINTS24
    SQUINTS24
    from Monrovia
    a Y-Block would be nice, or a 331 poly !
  23. oldsman41
    oldsman41
    i did a diesel in a 36 once it looked pretty cool
  24. I cant say I have ever seen one pedal powered before.
    (But I bet Povertyflats has one!!)
    The hard thing about being different here is, as a group we are all very different. Its hard to be a minority in a minority.
    How about going with a not so 'unique' power plant and build your 'uniqueness' into the motor. Nothing clichéd just a different or more agressive intake system?
    Doc.
  25. 1951coe
    1951coe
    from Manvel TX
    ****el rotary engine
  26. Pete1
    Pete1
    from Wa.
    You want different? Try a gas turbine..Probably no more than 10 hot rods running them now.
    Here is a pic of a 200 hp Boeing turbine in a 32...700 ft. lb. of torque at stall.
    When you turn the wick up you better be hanging on.
    A 500 hp model will also fit in a 32.
  27. MrFalcon62
    MrFalcon62
    Damn! I thought my little 400lb six cylinder was heavy!
  28. dakota tom
    dakota tom
    from dakotas
  29. captainjunk#2
    captainjunk#2
    studebaker v 8 with a paxton supercharger
  30. bshepherd
    bshepherd
    from michigan
