Just brought home a '62 Newport and there is a shifter issue. Basically, right now R and D are stuck in and won't pop out. When I push the 1 or 2 ****on it goes into gear and will drive forward, but I can't access R, although it caught reverse and I was able to drive it off my trailer when I pushed in the N ****on. Here's a pic, you can see that the R and D ****ons never pop back out, even when you push in the N ****on. Anyone know what the issue might be? If it's a cable adjustment, would that account for the stuck push****ons? Any good tech articles on adjusting these? I've been searching around but I can't seem to find the info I need. Also, what the hell is that lever right below the ****ons? The one that says L and R on it? Did '62 Chryslers have park on them? Here's a pic, just for the hell of it, even though it's too dark for a good picture And another of the coolest dash ever, which I'm thrilled to learn still lights up.
I'd suspect that the stuck ****ons are due to something sticking in the push ****on mechanism rather than a cable adjustment. There are a lot of springs, latches and sliding things inside that mechanism. I'd remove the cover, and shoot some WD-40 or something into the mechanism and see if it'll free up a bit. Those electroluminescent dashes are the cats ***, aren't they? I had a 67 Charger with that type of lighting. Even the needles on the gauges were coated and lit up. Note that there is a DC-AC inverter under the dash which lights up that ceramic coating, and it generates about 225 volts AC at about 250 Hz. It can bite yer *** if you're reaching around under the dash with the lights on. My 64 had a park lever, but it sure didn't have the L/R on it. Is it for adjusting mirrors, or maybe to open vents? Does it seem like it's connected to a cable, or a switch?
Had the same problem on my '58 - squirted some Kroil around the push ****ons and let it soak overnight - all was well and the sun was shining next morning. I have had one of those dash pods sitting on my desk for years just because they are so uebercool....
I have had the same problem on my '60 New Yorker a couple of times. Both times, it was bound up on the cover. Use an allen wrench to remove the cover, and it popped back out. The L/R lever is the turn signal switch. And yes the lighted gauges are awesome and it will curl your hair if you are in the ground path!
Could be stuck in several place Like above says, figure out is its the ****ons first I could be the cable to easy enough
You might want to search the Forward Look and Imperial club sites for any discussion there or tech tips regarding same.
