Sea Foam anyone?
Discussion in 'The Hokey Ass Message Board' started by swimeasy, Nov 15, 2010.
  1. swimeasy
    swimeasy
    Have any of you hoodlums ever used SEA FOAM? I was told that it really works but they have been saying that about'' mouse milks" for years!
  2. Normal Norman
    Normal Norman
    from Goshen IN.
    I worked with an older mechanic in the early 70s. He swore by it. Put it in gas tanks for upper end lube, down the carb to decoke the valves,in the engine oil to quiet lifters,etc.etc. Normal Norman
  3. sam1el
    sam1el
    I've used it on my cars and bikes. Seems to get junk out of the fuel system pretty well. Saved me a few times too.
  4. BulldawgMusclecars
    BulldawgMusclecars
    I used it on a high mileage OT car once...worked great, though be sure to run it outside your garage, because the stench is awful! Lots of smoke, too.
    BTW, its great for finding exhaust leaks, too...
  5. Mr Mayo
    Mr Mayo
    from Huff, ND
    Sea Foam has worked well for me. I used to mix it in my boat gas to absorb moisture like gas line antifreeze. It also is good for treating gasoline before you store your car, like "Stabil".
  6. Cleaned up my small 5hp engine.
    This new gas had gonked up the carb on it.
    Sea Foam is old school stuff.
  7. Ol Dawg
    Ol Dawg
    I don't think much about SNAKE OILS,but that stuff is the BEST.You can get it as a spray or a liquid.If you try it I'll bet you will like it.
  8. Chris Stapley
    Chris Stapley
    We have constant problems with fuel in small engines now that they're trying to shove that corn sqeezings (ethanol) **** on us. The carbs will go completely green inside with algae seemingly overnight. My poor old weedeater won't hardly stay running without using the Seafoam. It keeps on running now that I use it though, also works out great for the old cars that tend to sit a lot around our garage....
  9. tubman
    tubman
    "Mechanic in a can":D
  10. And I thought you were talkin about the color lol Pete.
  11. Leevon
    Leevon
    from Nixa, MO
    1 can in the full gas tank, 1/2 can in the crankcase (right before an oil change) and **** 1/2 can into the intake through a brake booster hose or just dump it right in. Shut the engine down, let 'er sit for a few, start 'er back up and watch the smoke show. Change the nasty oil and enjoy.
    Sounds like a drink recipe, I'll have mine on the rocks please.
    It does a good job of removing carbon (in my world anyways).
  12. gaspumpchas
    gaspumpchas
    YEP, magic stuff...got my daughters OT 88 nissan thru colorado emissions using sea foam, by advice of some local guys.....sweet stuff, can now get in wallymart
    gaspumpchas:D
  13. The "Trans Treatment" is the BOMB! Fixed MANY a slipping trans! Like an early 700R4! Great product(s).
  14. Sea Foam is awesome stuff! I totally believe in it 100%!
  15. shainerman
    shainerman
    It is truly the best thing you can purchase for any vehicle. And thats that.
  16. B.A.KING
    B.A.KING
    sea foam has a trans treatment???? have not seen that?
  17. Sea Foam's #TT16 is called Trans Tune, great stuff, not a leak stop but a valvebody cleaner. And the liquid cleaner for engines is #SF16, great product as well and the aerosol spray cleaner Deep Creep #DC14. I have a lot of positive response on all these fine chemicals, always good to hear positive feedback from satisfied customers.
  18. pontiac
    pontiac
    I've used Sea Foam in everything... awesome stuff... the transmission treatment is great too.
  19. 61 chevy
    61 chevy
    whats with the name, looks like they would call it CAR HELPER or motor fix, something like that.
  20. bigdog
    bigdog
    It was originally devoloped as a marine fuel additive-hence the name. Great stuff.
  21. hoodprop
    hoodprop
    I have used it in motorcycles,quads, small engines and cars and it has helped to clean out the fuel systems without any promblems
  22. Another thumbs up from me......
  23. I've known mechanics who use it and like it. But it've seen it in action, and it really smokes up the neighborhood.
    Rather than that, though, my preference (sorry for the blatant plug) is Techron Concentrate. I have first-hand knowledge of its cleaning strength and power restoration capabilities. We've carefully weighed intake valves before and after treatment. Also done dyno power testimg on the "before" vs the "after" intake valves. The stuff really does work.
  24. Ralphies54
    Ralphies54
    never heard of it in new england. What's a container look like, and where is it available ?
  25. Limey Steve
    Limey Steve
    Alliance Vendor
    from Whittier
    I've only heard good about it , yet to try it here.
  26. -Brent-
    -Brent-
    It comes in a red and white can.
  27. Roger Walling
    Roger Walling
    I pumped it full strength into a 56 Ford carb that has sat for 8 years with an electric pump, let it sit for a day and Voom!!! idles like a dream. Ps, 19,000 original miles on the F750, Lincoln engine. Bought it at NAPA.
  28. Muttley
    Muttley
    I've seen it at Walmart.
  29. Edelbroke
    Edelbroke
    I had a 302 ford motor that was seized up from being stored in a very humid farm building. It only sat for about 3 years but it was locked up tight. I put the motor on a stand took the spark plugs out of one side and turned the motor so I could fill the cylinders up with Seafome. Let it sit for 3 days and did the other side. It worked great, Motor spun right over. And actually ran very well and didnt smoke
