Hot Rods '36 chevy steering column removal
Discussion in 'The Hokey Ass Message Board' started by Hondo78, Nov 14, 2010.
  1. Hondo78
    Hondo78
    Anyone help with some info on removal of the steering column in a 1936 chevy coupe? Do I pull the steering wheel and drop the box and column or pull the steering box and remove the plate on the firewall and pull it out up through the floor as a unit?
    Any help will be helpful,
  2. HobbyPoor
    HobbyPoor
    from Cochran Ga
    im going thru the same **** with a 54....seems to be a pain in the ****
  3. tb33anda3rd
    tb33anda3rd
    i've always pull the wheel and drop it down. but i do it on the lift. the trick to getting the wheel off is to drill and tap two holes for the steering wheel puller. i've also tapped the horn ****on holes. don't try to hit or pull on the outside of the wheel it will break.
  4. kelzweld
    kelzweld
    I pulled the wheel and outer column, then unbolted the steering box with inner shaft still attached to it.
  5. 39cent
    39cent
    from socal
    I pulled the steering wheel unbolted the steering from the dash, jacked up the front end of my 39 Buick disconnected the tie rod, and pulled it out from below.
  6. Hondo78
    Hondo78
    Thanks I will start with removal of the wheel, however I don't want to ruin the horn ****on, any tips on the removal of the horn to expose the steering wheel nut?
    A putty knife leverage or does the ****on ***embly unscrew?
  7. pasadenahotrod
    pasadenahotrod
    from Texas
    Most early ****ons on Non-Fords or Fords after 1939 come off by a push in and twist to the left. They have a spring holding tension on them and some have a rubber donut underneath which can be deteriorated and holds 'em in like glue, eith crumbly rock glue or gooey glue.
  8. The last '54 I did came up through the floor, but it was a clunker and I can't remember if there was much of a floor to worry about.
  9. Hondo78
    Hondo78
    Thanks I removed the '36 Chevy std steering wheel, the retaining nut and pulled the steering box bolts, and down through the floor we went, after jacking up the car a few inches.
    Thanks again.
  10. harleyjohn45
    harleyjohn45
    Did the entire shaft go down thru the floor.
    John
  11. harleyjohn45
    harleyjohn45
    S
    I have plans to send my sector to Rock Auto for rebuild and wasn't planning the entire steering shaft.
