I used vintage air, I have some pictures in my photo album. GENII system, used there center pod with vintage controlls, blocked off two of the vents from the evaporator, Keeps my Merc kool! E
I used a 1965 Mustang under dash unit and bought all the rest of the components from Nostaligia Air Parts. My whole set up was under $500, and it blows ICE cold.
Window cranks in mine. Missing one so I kept the clip off the driver's crank so it could be used on ft and rr.
I have a'50 ford with a dual carb flatty, I used the vintage air and mounted the compressor where the gen goes, and used a gm type alternator on the side. Their rectangular control panel fits in the hole the original radio was in without butchering the dash. I removed the p***enger side vent and ran the lines through that space. I kept the driver side vent as original for those days/nights I did not need the air, sure am glad I did..........
Got my whole package from Hot Rod and Custom Supply out of Cape Corral Fl. Vintage Air. Kit fit perfect.....
Do you have any pictures? Mine has radio delete and twin Strombergs. I’ll need A/C this summer. Sent from my iPad using H.A.M.B.
