What oil pan do I need for my 302 powered A
Discussion in 'The Hokey Ass Message Board' started by hotrodnewby, Nov 22, 2010.
  1. hotrodnewby
    hotrodnewby
    Yes, I have used the search. Answers for alot of other models but I didn't see any about sbf's in A's. I've got a 69 block with a Fairmont double sump pan on it. Is this the pan I need? I'm going traditional steering with split A bones. Thanks,
    Newby
  2. FORD FAN
    FORD FAN
    I had a front sump pan on my model A. but I believe front, rear, or double hump will work. The tie rod and drag link should be in front of the engine with cross steer and with side drag link ,not an issue. One thing to be aware of is the oil filter potential interference if you use a Vega box or other cross steer box.
  3. dirtbag13
    dirtbag13
    yep im using a regular front sump pan on mine no problem ! and ford makes a short oil filter that worked for me to clear the steering box
  4. tuckpoint
    tuckpoint
    from omaha,nebr
    70's ford p/u has front sump .Get the pick-up tube with it.
  5. hotroddon
    hotroddon
    I've done 3 model A's with SBF, all of them I used regualr front sump standard pans.
  6. hotrodnewby
    hotrodnewby
    Thanks! Having the HAMB really shortens the learning curve for us newbs!
  7. tedley
    tedley
    from canada
    30 year old build pic here, front sump, 66 mustangbox, drag link
