muncie 3 speeds
Discussion in 'The Hokey Ass Message Board' started by chascue1, Nov 17, 2010.
  1. chascue1
    chascue1
    would like to know what years the heavy duty mc1 muncie 3 speed were used ........i know they were in '69 carmaros etc...were they also used in the '70's chevy pickup trucks ?........i would like to find a wider ratio low gear unit, the '69 chevrolet car was a close ratio 2.42 ....thanks for any input......charlie.....'37 and '41 willys.....'71 nova......:confused:
    1Nimrod likes this.
  2. 56sedandelivery
    56sedandelivery
    This is from my 71' edition CHILTON'S: Chevrolet Camaro, Chevelle, Chevy II, and Chevrolet (I guess they mean full size cars?) 69-70; 70 Olds F-85 and 442; 70 Pont Grand Prix, 70 Tempest, GTO, and Firebird. This is not the truck manual. Butch/56sedandelivery.
    1Nimrod likes this.
  3. bobss396
    bobss396
    I'd look for a 1970's truck unit that was behind a 6-cylinder. Other than that, I prefer truck boxes over car boxes. At the worst you may have to remove the side cover and count teeth on 1st gear or decode it from the ID numbers.
    Bob
    1Nimrod likes this.
  4. R Frederick
    R Frederick
    from illinois
    I have a Muncie 3 speed and was contemplating using it in my 50 Chevy car. I'd be interested to know why it may be more desirable than a four speed.:confused:
    1Nimrod likes this.
  5. bobss396
    bobss396
    For my every day driver, the 3-speeds worked well for me and I can get one in a truck yard cheaply when I want one. The 3-speed truck boxes always had a steeper 1st gear than the 4-speeds, great in a heavy Belair.
    Put a Hurst 4-speed t-handle on it and no one is the wiser, unless they get to drive it. Not that I'm out to mislead anyone, just like the t-handle over the ball.
    Bob
    ProtoTypeDesignFlauz and 1Nimrod like this.
  6. They are not necessarily more desirable just that they were cheaper sometimes cheaper is better. They got used by the roudny round guys alot because they didn't need the extra gear and they were lighter.
    They were or are pretty stout and for the price you normally can't find a 4 gear as stout as the Muncie 3 gear.
    1Nimrod likes this.
  7. bobss396
    bobss396
    That's how I got hooked on them. If the track rules permitted, take out whatever gears you don't need. Chew one up on Saturday night, find another first thing on Monday morning. The truck units were incredibly strong.
    Bob
    1Nimrod likes this.
  8. Mr48chev
    I've had one in my 48 for years simply because my buddy says, "here your truck needs this". Good solid box with full syncros including reverse.
    1Nimrod likes this.
  9. jcmarz
    jcmarz
    from Chino, Ca
    The man doesn't like to fondle balls, he likes to stroke the log!
  10. joe_padavano
    joe_padavano
    Sorry, but Olds never used a Muncie 3 spd. The only three speed transmissions used by Olds were the Saginaw 3 spd in the lower HP cars and the Dearborn (don't call it a F-O-R-D!) toploader three speed in the 442s and the full size cars. I suspect that the toploader was also used in the Pontiacs in that list.
  11. 40Standard
    40Standard
    from Indy
    a p***enger car ****** will not fit a 70 truck bellhousing. the truck bellhousing has a bigger hole. I'll send you a PM about a ******
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
    When I was in high school, one of the "older" guys (23) had a '69 Judge with a Muncie three speed in it (who the hell would pay for a Judge but not a Muncie four speed?). I bought it from him when he swapped to a four speed and put it in my '57 Chevy. It took a lot of abuse from me, but never failed.
    1Nimrod likes this.
  13. bluice68
    bluice68
    from New Mexico
    I replaced the Saginaw three speed in my 1968 C-10 with a Muncie M-13 three speed. I was out of a 1974 Chevy van and I do beleive that it was a six cylinder van. Trans had a cast iron case, used regular Muncie four speed sychros and small parts (hubs sliders bearings, seals, dog rings, etc.). Service parts will not be a problem for ya. It also had the larger front bearing support to fit into the truck bellhousing. p***. car three speeds use a smaller one! Best of all first gear was a stout 3.03:1. With the 3.73:1 rear axle ratio, truck left the line quick! Yeah i drag raced it regularly too. i was still using the three on the tree shifter becuse is could not find a decent truck floor shifter conversion at the time. i tried several, but they were all made too cheaply and not very strong. I broke the Saginaw gearbox many many times, but i never broke the Muncie! Good luck!
    1Nimrod likes this.
  14. bobss396
    bobss396
    I've swapped front bearing retainers, turned them down on a lathe, made spacer rings for them too. With a little ingenuity, any combo can be made to work.
    Bob
  15. joe_padavano
    joe_padavano
    Sorry, but again, it was not a Muncie. The GTO and 442 both used the Ford Toploader three speed manual trans.
  16. 40Standard
    40Standard
    from Indy
    you're right, I learned that on a truck board. thanks
    1Nimrod likes this.
  17. joe_padavano
    joe_padavano
    1Nimrod likes this.
  18. bobss396
    bobss396
    1Nimrod likes this.
  19. hotrodstude
    hotrodstude
    i have seen only the toploaded in 65 up gm products(cars) when hd was involved. owned 66 PONTIAC with a 3 speed on columb,friend had 65 2+2 with 421 and toploader,seen 65 buick skylark gs,64 lasaber,and 67 olds
    1Nimrod likes this.
  20. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Sorry back at you, but I know the difference between a Muncie three speed with a cast iron cover on the side and a Dearborn gearbox with a tin cover on the top (and, no, it wasn't a Saginaw; I know all about them, too). It came out of a '69 GTO Judge and went into my car--no, I don't have a copy of the build sheet in my pocket and no, I didn't research the car's history before I gave him $40.00 for the transmission and factory Hurst shifter.
    1Nimrod likes this.
  21. Truckedup
    Truckedup
    I've head the HD Muncie 3 speed was used in other GM cars besides Chevys.If a Ford Toploader was used in GM cars,it must have used a GM type clutch spline or used a completely different clutch housing and disc being the Ford clutch shaft is a different length and spline and ****** bolt pattern than GM.And the pilot bushing and output spline too.
    1Nimrod likes this.
  22. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Im using a muncie 3 speed in my hotrod. Stood well with no complaits behind a 300 hp 350. See how it'll do behind a 450+ hp 327.
    I paid $25 for it 5 years ago. Never even had it open. Top gear is starting to whine a little so probably time for a rebuild.
    1Nimrod likes this.
  23. chascue1
    chascue1
    thanks for the information guys.........i know the muncies 3 speeds weight about 20-25 lbs more than saginaw 4 speeds.....also the gears are wider than the saginaws or even muncie 4 speeds.......charlie.......:(
    1Nimrod likes this.
  24. 6narow
    6narow
    Pardon me for resurrecting an old thread, but does anyone know the ratios of a Muncie 3-speed?
  25. indyjps
    indyjps
    When did this become a rule on HAMB? other boards are "sensitive" on post bumping, I've never seen it be the case here. Hes asking relevant info in a thread about a topic that already exists.
    There are mods in place already, apply if you want to be one.
    6narow and Desoto291Hemi like this.
  26. They make an adaptor ring for that.
  27. MMM1693
    MMM1693
    What is the best way to tell the difference between the Saginaw and Muncie ******s
