60 kingswood wagon......meet helen
Discussion in 'The Hokey Ass Message Board' started by ryno, May 14, 2010.
  1. ryno
    ryno
    ***uming your talking about the front fenders? lower bolt that goes into a insert on the bottom?
  2. Uhh, Well, It's the front fenders, Yeah. But it's on the inside of the panel, behind the wheel, In an insert i think, Yeah.
    Basically i can't access it with a grinder.
  3. YoungGun
    YoungGun
    what did you do in the front to get it to lay i bought tubular control arms. and cut the spring pocket..do you have any pix?
    i actually built mine with stock arms then bought tubular in middle of build and wow they require very little cutting
  4. YoungGun
    YoungGun
    also a notch for my tie rods...
    any pix would be awesome
  5. ryno
    ryno
    id have to take a look tomorrow, but i believe there's a bolt from the under side that goes up into the insert.
    i don't really have any front pics, because it is pretty straight forward. i used a cpp 2" drop spindle kit with 12" disk's. some cutting of teh pockets and frame lip is required. i didn't have to notch my tie rods, just make sure the adjuster bolts are face down.I'm also setting this up to run a 215/75/15 tire. if you where to run a bigger tire you may have to clearance more. ill get you some pics when i get everything blasted and do the final ***embly.
  6. YoungGun
    YoungGun
    the smaller tire really helps..i was running 20s
  7. ryno
    ryno
    ya, you must have been running a tall tire, because the tires on there now are almost 28" tall.
  8. The Hank
    The Hank
    from CO
    Is that your 65 Impala on the first page?,all you see is the rear of the trunk.
  9. ryno
    ryno
    no it was in the yard where i found her.
  10. Midwest Rodder
    Midwest Rodder
    Damn nice job so far!
  11. GaryB
    GaryB
    from Reno,nv
    nice wagon I missed one by THIS much
  12. ryno
    ryno
    thanks for the complements guys.
  13. bulletproof1
    bulletproof1
    from tulsa okla
    looks good....we going to cruise it to the pile up?
  14. zman
    zman
    from Garner, NC
    This is one of the most ignorant comments I think I've ever seen on here. The guy goes out of his way to do something right. To actually rid an old car of all the rust so it isn't slowly rusting away and you say that. That's some ******** right there. The whole patina fad is stupid. :eek:
    Sorry Ryno, I just can't hold my tongue when I see **** like this. Bravo on you for doing it right.
  15. ryno
    ryno
    hopefully we'll be heading south for the round up in April, then north for the pile up, that is if my money tree out back does not freeze this winter, **** ain't looking good right now!
    no sweat man. i had to read that a few times myself when he posted that. to each their own i guess. i mean i would never , ever , spend all that coin on stock replacement **** like he did and leave the outside, let alone actually spend money and time to try and clean up the patina and then clear it like he did. but it is his car and poor choices.
  16. Hollywood-East
    Hollywood-East
    Wicked Kool Wagon!!! Nice work!
  17. bulletproof1
    bulletproof1
    from tulsa okla
    well maybe we need to have a thrash some weekend .me and rashy can come up ..we owe you one ...
  18. ryno
    ryno
    sounds good to me. you guys are always welcome.
    you need to keep rash master focused on the elco, the round up is fast approaching!
  19. tcb-1
    tcb-1
    you sir, deserve an A for effort....... that's even with the crown royal talking.
  20. gonmad
    gonmad
    Lookin killer man! Anxious to see it completed!
  21. YoungGun
    YoungGun
    my tires were 26.5" tall...i didnt have drop spindles though..i wanted to keep the drums all around
  22. ryno
    ryno
    that makes sense then. ya better keep an eye on your ball joints. with that much cutting to get it to lay, your joints are in a huge bind in the upper most travel. i looked into keeping my drums also, but didn't like the angles and bump steer that will come because of them.
  23. ryno
    ryno
    got the motor pulled apart, and decided to smooth it out a little.
    from this:
    to this:
  24. ryno
    ryno
    little update.
    got the motor and 700 r transmission all back together.
    decided on a key lime with kandy pagan gold color scheme, heavy flake and panels
    been working on getting the floors all ****oned up. will post some pics soon.
  25. 38FLATTIE
    38FLATTIE
    from Colorado
    Cool build Ryno- love to see it when I'm down there. Colors sound interesting.
    Nice work!
  26. Nads
    Nads
    from Hypocrisy
    Beautiful, I'm enjoying this build very much.
  27. ryno
    ryno
    any time man.
    thanks
  28. ryno
    ryno
    its been cold in the shop!
    some floor pics, cu tout the rusted area, fabbed up new piece, bead rolled some, weld up, repeat!
    picked up some impala side trim and birds. going to use that instead of the std wagon trim.
    was able to pick up some corvette valve covers also
    lewk likes this.
  29. jfrolka
    jfrolka
  30. ryno
    ryno
    finally got some time to work on the wagon again.
    been busy doing the reg. job
